If statement error on multilingual website
November 08, 2012 6:57am
  • #1 / Nov 08, 2012 6:57am
    milogdm
    Hi I run an installation of EE 2.5.3 using the multilingual trick where I configure the country code in the global vars using the index.php file for each language as described in the wiki:
    $assign_to_config['global_vars'] = array(
      "country_code" => "en",
      "language" => "english"
    Everything works fine for all the languages I have defined, but recently I tried to add to my header a meta-tag for the language, so I added this to my header (it’s a partial template):
    {if country_code == "en"}
     <meta name="language" content="English" />
    {if country_code == "fr"}
     <meta name="language" content="French" />
    {if country_code == "zh"}
     <meta name="language" content="Chinese" />
    {if country_code == "de"}
     <meta name="language" content="German" />
    The if structure it’s very similar to the one I have used inside the others templates. The output I get it’s an error for French and Chinese, but works fine for English and German.
    English it’s on the main folder of the installation.
    This is my error:
    Parse error: syntax error, unexpected T_ENDIF in /home/example/public_html/system/expressionengine/libraries/Functions.php(680) : eval()‘d code on line 5
    I don’t get this error in any other place of the website.
    Thanks for your help.
  • #2 / Nov 08, 2012 3:48pm
    Dan Decker
    Hi milogdm,
    Sorry for your trouble here!
    I did some quick tests to make sure there wasn’t an obscure bug with “de” or “zh” and everything checked out for me.
    What I suggest is going back into those 2 index.php files and double checking that the array is properly formatted.
    If everything checks out, I’d like us to get a look at it.
