EE 2.5.2 channel entries modified/edit date is not accurate
November 07, 2012 9:12am
  • #1 / Nov 07, 2012 9:12am
    glenndavisgroup
    Hi Guys,
    We are using EE 2.5.2 and we noticed something strange with the modified/edit date stored with each channel entry. It seems this field is adding extra hours to any entry we edit and save. Here is how we tested:
    Test1:
    I added a new channel entry to my channel. The entry date for example will have today’s date and the time will be 8:30am but the modified/edit date is the same except the time is set to 9:30am. It’s adding about 1 hour more to the modified/edit date/time.
    Test2:
    If I now go back to edit the entry in test1 above after only 5-10 minutes later and I save the entry the modified/edit date/time now adds 5 hours more to the time instead of just updating it with the current date and time.
    I have checked both the EE localization settings and my user localization settings they are both correct. I’ve also checked our Ubuntu server date/time and they are correct. We never noticed this before until we installed Zenbu and started customizing our channel entry list display to show the edit date so we can sort by it.
    Is there a reason for EE to be adding this many hours to the modified/edit date/time? Has anyone seen this before? Any help or clarification is much appreciated.
    Thank you,
    Mike
  • #2 / Nov 07, 2012 3:53pm
    glenndavisgroup
    Can someone from EE verify if this is a bug please?
    Mike
  • #3 / Nov 08, 2012 11:47am
    Shane Eckert
    Hi glenndavisgroup,
    This sounds like this bug. Except in your case your second save date is +5 hours which sounds like this bug where second save is GMT.
    Does that sound about right to you?
  • #4 / Nov 08, 2012 11:52am
    glenndavisgroup
    Hi Shane,
    Thank you for the reply. Yes, that’s exactly what’s happening. I will take a look at the bug reports and see if there is a work around and use that for now until the fix is applied. Thank you for verifying that for me.
    Mike
  • #5 / Nov 08, 2012 3:08pm
    Shane Eckert
    Hey Mike,
    No problem. I know how annoying these bugs can be.
    Please let me know if there is anything else you need.
  • #6 / Nov 09, 2012 9:09am
    glenndavisgroup
    Hi Shane,
    The change in the bug report works great. You can go a head and close this post.
    Thank you,
    Mike
  • #7 / Nov 09, 2012 10:08am
    Shane Eckert
    Hi Mike,
    Awesome! Glad to hear it!
