htaccess help
November 07, 2012 8:20am
  • #1 / Nov 07, 2012 8:20am
    Royama Design
    I seem to having an issue with my htaccess and not sure what the proper solution is. Hoping someone here might have an answer.
    When I enter “domain.ca/bob”, I want to be redirected to “www.domain.ca/bob”. Instead, I get “www.domain.ca/index.php/bob”. Not sure why the index.php gets chucked in. Do I have to add something extra to remove the index.php segment? I am already using the remove index.php code in the htaccess.
    RewriteEngine On
    RewriteBase /
    # Removes index.php
    # Redirect for non-domain to www-domain
    rewritecond %{HTTP_HOST} ^domain.ca
    rewriterule ^(.*)$ <a href="http://www.domain.ca/$1">http://www.domain.ca/$1</a> [L,R=301]
    # Other redirects below here
  • #2 / Nov 07, 2012 7:56pm
    John St-Amand
    In the control panel, check in Admin > General Configuration > Name of your site’s index page - do you have index.php in there?
  • #3 / Nov 07, 2012 7:59pm
    John St-Amand
    Ideally you’ll also have your htaccess file remove index.php even if it is present in the URL - so that you don’t have two URLs that display the same thing. Something like:
    # Redirect index.php Requests
    RewriteCond %{THE_REQUEST} ^GET.*index\.php [NC]
    RewriteCond %{THE_REQUEST} !/your_system_folder_name/.*
    RewriteRule (.*?)index\.php/*(.*) /$1$2 [R=301,L]
    Hope that helps.
  • #4 / Nov 08, 2012 8:16am
    Royama Design
    Hi John:
    I double checked my general admin settings and I had removed the index.php properly. So not that.
    I don’t really understand the htaccess code fluently. Do you mind taking a moment and describing what your additional code does on each line? How does it differ from what I am currently using?
    Thanks for your help.
