Hey Shane,
Thanks for your response. To make a point, I created this thread only after failing with Member Groups. I’ve detailed down my cases of failure with member groups, check to it.
Case 1:
In this case, I assigned different roles under member group for single user.
Am aware an user is common throughout the application to N number of sites created(with MSM module) and our requirement also demands the same.
I had two sites, let us assume X and Y with user named ‘Peter’. In site X and Y, I created new permission roles ‘Xperm’ and ‘Yperm’ respectively. Consecutively, in site X, assigned Peter to role Xperm. Similarly, in site Y, Peter was assigned to role Yperm.
In this way, I was able to found out only the bug within ExpressionEngine core or MSM module and not the solution for my requirement. For your referrence, I have attached the screenshot image with this post. Kindly check to it
Case 2:
In this case, I kept a common role and tried to configure the options with respect to site.
I created a new role ‘Xperm’ in site X. Then, I created the site Y, from site X, which had role ‘Xperm’ in default. I took two users by name ‘Sam’ and ‘Peter’, assigned both to single role ‘Xperm’. This case too didn’t help me to find a solution. I have attached an image(case-2-study.png) to explain my requirement. I tried my best to find a solution, but I didn’t.
Similarly, I tried to sort out this problem with different cases, but nothing worked good for me. Kindly refer to the case 2 attached image and try to get me a solution for it. Any help would be appreciated. Thanks in advance.
