Hey all, anyone know of a plugin similar to the EE1 Textile plugin I can use in order for my client to include headings and lists within a channel field?
November 05, 2012 5:50am
Subscribe [2]#1 / Nov 05, 2012 5:50am
#2 / Nov 05, 2012 7:07am
Wygwam is still available for EE1. You can strip it down to be pretty limited if you’re looking to keep your client’s editing experience fairly simple.
#3 / Nov 05, 2012 7:15am
Thanks but we are using EE2, I’ll check to see if this works
#4 / Nov 05, 2012 8:17am
Oh, sorry. I interpreted that to mean you were looking for an EE1 plugin. As much as I like Wygwam, I might suggest you also take a look at Wyvern. Same idea only I find for client purposes it can be set up to be even friendlier, dot dotted likes around HtML entities in the editor (each for example), AND the toolbar is setup per member group AND per custom field - so in two different uses you can have different settings (like upload folder) which I think is a pretty awesome way to keep the client out of trouble. Hope that helps.
#5 / Nov 05, 2012 8:20am
Exactly what I was after, thankyou 😉
#6 / Nov 05, 2012 8:39am
You’re very welcome.
