Urgent: Site down, possible malware
November 02, 2012 3:04pm
  • #1 / Nov 02, 2012 3:04pm
    koko.pelli
    Hi All,
    If you could help I would be very grateful. A client site has gone down and it looks like it could be a malware issue. When I go to the site in safari it says Warning: Visiting this site may harm your computer.
    The URL is http://www.thejudge.co.uk
    When I go with Chrome, I get the front page but with no stylesheet applied, and all internal pages are 404.
    When I log in to the control panel, I get a message stating the index.php file has changed and whether I would like to accept changes.
    Would really appreciate any advice you can give.
    Thanks in advance
  • #2 / Nov 02, 2012 3:40pm
    koko.pelli
    Edit* I have got the site back up, it seems they added some files to the root, and changes the htaccess file to try to redirect to http://onlinepartsupply.com
    Removed that and reconfigured the htaccess and the site is back up, but still not sure whether any other files were harmed.
  • #3 / Nov 04, 2012 11:42am
    koko.pelli
    I am still getting the malware warning, is there anything specific I can do to find out why that is caused?
  • #4 / Nov 05, 2012 8:56am
    Ian Ebden
    Hi. Sorry to hear about your attack. Happened to me once a while back and it’s not much fun. Chances are it was probably just a file-based attack, so your database should still be clean. I’d check it against a backup though all the same (you do take backups right?).
    First protocol is to change all your passwords – especially your FTP. Secondly, I’d look at changing host. Sounds dramatic, but if you’re on shared hosting there is obviously a weak point somewhere there that could be exploited again very soon. These attacks tend to recur once they’ve found you.
    Next, I’d check through all your directories looking for newly created files – especially .htaccess ones.
    Lastly, I’d strongly consider moving your entire system folder above the public webroot and renaming your admin.php. Pretty easy to do and practically eliminates such attacks from happening again:
    http://ellislab.com/expressionengine/user-guide/installation/best_practices.html
    Hope that helps.
  • #5 / Nov 05, 2012 2:57pm
    Shane Eckert
    Hey there koko.pelli,
    Ian is right on with his suggestions. It’s most certainly an infected file.
    Taking the security precaution is also a really great idea. Refreshing all your files would be good.
    Can you tell us where you are now? How are things going?
