Comma Separated Value Data Problem
October 30, 2012 10:38pm
  • #1 / Oct 30, 2012 10:38pm
    kalspaugh
    I am pulling data from the exp_channel_data table.  One of the fields contains name data in the format <lastname, firstname>.  I need to use this data in a php segment.  When I try to use this data it throws errors that I am passing two values to a function that only expects one value or “Use of undefined constant <lastname>”.  It is treating the single value as two comma separated values. I don’t understand why this is happening.  The value pulled from the db should be treated as a string…not two strings.
    How can I avoid this?
    I’m using ExpressionEngine v2.5.2 - Build Date: 20120606
    Kevin
  • #2 / Nov 01, 2012 11:34am
    Shane Eckert
    Hello Kevin,
    How are you pulling this data? Is this using a channel entries tag?
    Is this a custom script you wrote?
    Please let me know.
    Thank you,
  • #3 / Nov 01, 2012 12:49pm
    kalspaugh
    Hi Shane,
    I figured out what I was doing wrong.  I am pulling the data using the Query module.  When I was storing the name value to a php variable I forgot to wrap it in quotes.
    I was doing this $p_name = {field_id_4}
    when I should have been doing this $p_name = ‘{field_id_4}’;
    Kevin
  • #4 / Nov 02, 2012 3:18pm
    Shane Eckert
    Hey there kalspaugh,
    Awesome! Nice work getting it figured out!
