Hi Everyone,
It works wonders. I’m now using templates for everything static but replaced footer / header etc with the appropriate tags to link to other templates.
However now I’m running into problems with URL’s.
Edit - Delete - Clean up
I’m really lost.
Edit 3:
Okay so let me summarize:
1. I use templates for static pages
Group (design) / Name of template (crevision)
mydomain.com/index.php/design/
mydomain.com/index.php/design/crevision
a) How can I create sub-sub-pages?
2. I use channels for dynamic content / not main pages
a) So I should create a channel called ‘design’
b) How does the URL scheme work here? Will content in a channel automatically follow the structure?
When I try to save a new channel post ‘name’ under design, it will tell me the url is invalid. I can only save when I assign a new URL ‘name’ and then I can find it under mydomain.com/name ... Is this supposed to be?
3. So if I’m a single user, the page module / template module is similar?
a) I can only create main pages and assign templates e.g. mydomain.com/page
How can I create a sub-page? It won’t accept mydomain.com/page/page2
