File path spaces are replaced by '+'-signs after update
October 30, 2012 11:03am
  • #1 / Oct 30, 2012 11:03am
    srj.agency
    Hi there,
    I just updated one of my EE sites to 2.5.3.
    I had many many images in the old installation that had spaces in the filename (don’t ask 😉 ). Anyway, after the update, the links to these images have been ‘automatically’ updated to display spaces as ‘+’ instead of ‘percent20’. For instance:
    /images/uploads/someimage.jpg
    has changed to
    /images/uploads/some+image.jpg
    resulting in many imagepaths being broken.
    Can I fix this in a way that does not involve manually renaming all the files?
    Thanks! 😊
  • #2 / Oct 31, 2012 3:21pm
    Shane Eckert
    Hey there reinoud-jules,
    I am afraid you have run into this bug. Which I am sorry is the case.
    Can you try the fix in the bug and let me know if that helps?
  • #3 / Oct 31, 2012 8:29pm
    srj.agency
    Hi Shane, thanks for your reply.
    That is indeed the bug I encountered. I was on a tight schedule so I found another effective yet simple solution: downloaded all the files via FTP, replaced spaces with plus signs using Mac OS X’ Automator and reuploaded them. Worked like a charm!
    I assume newly uploaded files will function properly? If not, I’ll follow the instructions in the bug tracker.
    Thanks again, love EllisLab Support 😊
  • #4 / Nov 01, 2012 5:48pm
    Shane Eckert
    Hey reinoud-jules,
    Sounds like a decent fix. If the names are as expected, you should be good.
    If not, try the fix. I will leave this open a few days just to make sure.
    Have a great rest of the week and enjoy your weekend.
