Status not saved
October 30, 2012 3:21am
  • #1 / Oct 30, 2012 3:21am
    Heiko
    Hi there,
    I can’t change the status of a post anylonger. It’s simply not saved, when I select it via the drop down.
    Yes, I’ve already checked the status group permissions and channel assignments and I’m logged in as Super Admin.
    Anything else I might take a look into?
    Thanks.
    Heiko
  • #2 / Oct 30, 2012 3:26am
    Heiko
    Strangely, it’s working when I bulk edit entries via Zenbu.
    But I need the native functionality working too, because my main problem is, that the automated setting of statuses doesn’t work, which might be a related problem.
  • #3 / Oct 31, 2012 9:25am
    Heiko
    Ideas anyone?
  • #4 / Oct 31, 2012 1:15pm
    Shane Eckert
    Hello Heiko,
    What version of ExpressionEngine are you currently using?
    Were there any changes recently? Are you using any Add-Ons? Are they all up to date?
    Please let me know!
  • #5 / Nov 01, 2012 12:53am
    Heiko
    Yes, I am using addons - who’s not?! 😛 - and everything is up to date, except for EE itself, which is still v2.5.2 - and for good reason.
    Honestly, I don’t know, if this behavior is due to a recent change, because I didn’t test it before. I’ve set statuses via Safecracker all the time and it’s working as expected.
    Is there a way to disable all addons in one go, without losing any settings? If so, I couldn’t find it yet.
    Thanks.
  • #6 / Nov 01, 2012 5:54pm
    Shane Eckert
    Hey Heiko,
    So this is via SC on the front end?
    You may not know if the behavior is due to recent changes, but were there any recent changes? It will help me troubleshoot if I have this bit of information.
    Can you list out the Add-Ons that you are currently using? I am interested in seeing if an Add-On that you have installed may effect entries, so a list of those would be great.
    There is not way to disable all the Add-Ons, and there would be data loss depending on the Add-On, but that’s not always the case. Really depends on the Add-on.
    Once I have a little more information, maybe we can get to the bottom of this.
    It may also be much faster if I get a log in from you and take a look. If that ends up needing to happen, is that okay?
  • #7 / Nov 02, 2012 3:47am
    Heiko
    Thanks, Shane.
    I’d let you log in for sure, but I’m still running the site locally, so I’d love to avoid having to deploy it as long as possible.
    The problem does only occur, when I try to set the status via the CP. SC works fine.
    So, I’m using these addons. Any known “troublemakers” among those? 😉
    I’ve attached a screenshot, so you can see the blank status-fields.
  • #8 / Nov 02, 2012 4:31am
    Heiko
    I just noticed that I can not only not alter statuses, but anything at all via the backend. Not even the entry-title. Nothing is saved, when I make changes via the CP. And I can’t even create new entries that way.
    OK, I’m going to uninstall each and every addon now to see if I can find anything.
  • #9 / Nov 02, 2012 4:44am
    Heiko
    Damn, I found it!
    I had a required field in there, which didn’t let me save the entry per se and I didn’t notice the validation error somehow.
    Now, that’s embarrassing! Sorry for the fuss… ;(
  • #10 / Nov 06, 2012 12:32pm
    Shane Eckert
    Hey Heiko,
    Ha! Glad you found the resolution!
    No worries, really glad that you got it sorted.
