I need to optimise the following code and therefore seek assistance doing so if anyone can suggest any optimizations.
Note collections is a table I have created in the database and it only has a handful of records and only 3 fields.
This code may or may not be the culprit causing me fatal out of memory errors but I would like to ensure it is as optimised as possible.
{exp:query sql="SELECT id, libraryitemid FROM collections WHERE id = '{logged_in_member_id}' "}
{exp:channel:entries channel="library_items" entry_id="{libraryitemid}" dynamic="no" disable="categories|member_data|pagination"}
{title}
{/exp:query}
