The site I am developing has had an SSL certificate added and I just tried to access the control panel using
https://www.mysite.com/admin.php
Unfortunately the control panel appeared with no styling. It appears fine with the following:
http://www.mysite.com/admin.php
So I am hoping there is a fix. My system folder is located one level about the public_html root just in case this has any bearing.
Here are the settings from my General Configuration
URL to the root directory of your site
URL to your “themes” folder
http://www.mysite.com/themes/
Theme Folder Path
/var/sites/r/mysite.com/public_html/themes/
Default Control Panel Theme
Default
Ideally the control panel should work on both the following URLs:
i.e with or without the https
Any help much appreciated as always
