Strange template-parsing when strange URL is entered
October 16, 2012 1:40pm
  • #1 / Oct 16, 2012 1:40pm
    lehrerfreund
    my URL-structure is like:
    domain.com/schule/1s/entrytitle
    or
    domain.com/schule/1s/entrytitle/entrynumber
    If you try this, you will see a normal, correctly rendered page: http://www.lehrerfreund.de/schule/1s/lehrer-gehalt-schweiz/4211
    For some unknown reason Users come from Google with an URL where the last slash is missing, that means: http://www.lehrerfreund.de/schule/1s/lehrer-gehalt-schweiz4211
    This URL generates a malformed page: The content (= the article) contains just an
    and the headline to enter a comment (see attachment).
    Is there any way to fix this? I mean to redirect to 404 in such cases or something similar.
    I already have a 404-redirect in my single-entry-template, but this does not work in this case:
    {exp:channel:entries channel="{my_channel}" ..........
    {if no_results OR segment_5!=""}{redirect="schule/404"}{/if}
    Thanks in advance!
  • #2 / Oct 17, 2012 11:55am
    Dan Decker
    Hi lehrerfreund,
    I’m sorry for your experience with this!
    Your redirect should work, but I think you need to check for segment_4
    <a href="http://www.lehrerfreund.de/schule/1s/lehrer-gehalt-schweiz/4211">http://www.lehrerfreund.de/schule/1s/lehrer-gehalt-schweiz/4211</a>
                                            (1)     (2)             (3)                 (4)
    If you change your conditional to check segment_4, what are your results?
    {if no_results OR segment_4 == ""}{redirect="schule/404"}{/if}
  • #3 / Oct 17, 2012 2:21pm
    lehrerfreund
    Hi Dan,
    no, “4211” is segment 5 in my case (counting starts with schule = 1). I use the segment-parameter in some other contexts and there it’s similar.
    So this is not the case; perhaps the problem has to do with this line in the htaccess (but I don’t think so):
    ErrorDocument 404 /schule/404
  • #4 / Oct 18, 2012 1:55pm
    Dan Decker
    Hy lehrerfreund,
    Lets get a look. Be expecting an email from EllisLab!
  • #5 / Oct 18, 2012 4:11pm
    lehrerfreund
    Thanks Dan,
    replied to it, good luck under the engine hood.
  • #6 / Oct 19, 2012 4:44pm
    Dan Decker
    Hi Berthold,
    We have your information and will be working with you there. Once we have a solution, we’ll post back here with a follow up.
  • #7 / Nov 02, 2012 6:26pm
    lehrerfreund
    Uah, this was tricky, but Kevin could fix it (thanks Kevin!).
    Thanks for all the support!
    (my case closed)
  • #8 / Nov 02, 2012 6:45pm
    lehrerfreund
    Perhaps I should mention the solution 😊
    This conditional:
    seeems not to work in this specific context. I had to split it up in two simple conditionals:
    {if no_results}{redirect="schule/404"}{/if}
    {if segment_5!=""}{redirect="schule/404"}{/if}
  • #9 / Nov 05, 2012 12:20pm
    Kevin Smith
    Glad I could help figure this one out, lehrerfreund! Have a good one.
