404 Not Displaying When Expected
October 16, 2012 10:41am
  • #1 / Oct 16, 2012 10:41am
    LuCmf
    I’m trying to display 404 whenever the segment_2 is not a valid url_title.
    I’ve enabled strict URLs in the control panel.
    My template code looks something like this:
    {exp:channel:entries channel="blog" limit="1" disable="member_data|pagination" dynamic="yes" require_entry="yes"}
            {if no_results}
              {redirect="404"}
    The thing is the no_results conditional isn’t working. It shows nothing…
    I tried with text instead of the redirect and it doesn’t show either.
    Any suggestions?
    Lu
  • #2 / Oct 16, 2012 5:56pm
    Is it possible to link to an example page?  And to make sure you’re viewing the template you think you are- might make a test template and put on the top ‘This is a test’- outside of the tag.
    It’s also a good idea to turn template debugging on - in Admin- System Prefs- Output and Debug.  Let’s see if that gets us a little more info when you visit the test page.  Note- without a url_title or entry_id in the url, that should redirect you.  Make sure you do have a 404 template selected.
  • #3 / Oct 17, 2012 7:31am
    LuCmf
    I tried that part of the code in a blank template and it worked fine.
    So I decided to make a new template with the single entry code and embed it in the huge template it was in.
    This way it worked perfectly.
    Thanks for your help!
  • #4 / Oct 17, 2012 4:44pm
    Aha!  Yep- sounds like something was conflicting.  Embeds are parsed independently, so moving it out eliminated whatever weirdness was happening.  Glad you got it squared away- those can be a bear!
