Simple Search no results error when there are results
October 15, 2012 11:03pm
  • #1 / Oct 15, 2012 11:03pm
    Warble Media
    I have a Simple Search form in my template:
    {exp:search:simple_form channel="products" search_in="everywhere" result_page="products/search" form_class="search form-inline"}
        <div>
            <label for="keywords" class="visuallyhidden">Search</label>
            <input type="search" name="keywords" id="keywords" maxlength="100" placeholder="Search our store…">
            <button type="submit" class="btn">
                <i data-icon=""></i>
                <span class="visuallyhidden">Search</span>
            </button>
        </div>
    {/exp:search:simple_form}
    But when the form is submitted I always get the standard gray EE “Your search did not return any results.” error page.
    I have looked in the DB and the searches are being logged:
    id   site_id  member_id   screen_name     ip_address      search_date  search_type     search_terms
    19  1        1            Jeremy Worboys  127.0.0.1       1350354904   site            Bella
    and the row in the DB shows results are being found:
    search_id                           site_id  search_date  keywords    member_id   ip_address  total_results   per_page    query   custom_fields   result_page
    3a94a35005ffa2af06a6e43c6a9228ab    1        1350354904   Bella       1           127.0.0.1   11              50          [...]   [...]           products/search
    and if I take the SQL in the `query` column and run it I can confirm it is finding the 11 results.
    Let me know if you need any other details.
  • #2 / Oct 16, 2012 4:21pm
    Is it possible to link to the site in question?  If you’re getting no results, I’m wondering if the search_id is being interpreted wrong due to ... something.  That would give a ‘no results’, despite being results.
  • #3 / Oct 22, 2012 1:18am
    Warble Media
    Hey Robin,
    I didn’t get a notification that you replied. The dev site can be accessed at http://kidsonabington.jeremyw.me
  • #4 / Oct 22, 2012 9:42pm
    Shane Eckert
    Hey Jeremy,
    Are you using a htaccess file?
    If you are, can you paste the contents in here?
    If not, I think we may need to get in a take a quick look.
    Thank you,
  • #5 / Oct 22, 2012 9:47pm
    Warble Media
    Hey Shane,
    Yes, it is a little long so I have put it here: http://pastebin.com/mGjgLSCg
  • #6 / Oct 22, 2012 10:03pm
    Shane Eckert
    Hey Jeremy,
    Wow! That’s quite a file.
    Just for testing, what happens if you set that aside for a second and then try the search. Does that fix it?
    You may need to actually replace your current htaccess with this one because you have removed index.php.
    <IfModule mod_rewrite.c>
            RewriteEngine On
            # Removes index.php
            # If 404s, "No Input File" or every URL returns the same thing
            # make it /index.php?/$1 above (add the question mark)
    </IfModule>
    Please let me know the results.
  • #7 / Oct 22, 2012 10:09pm
    Warble Media
    Just tried your code with and without the question mark. Still no luck.
  • #8 / Oct 23, 2012 5:29pm
    Shane Eckert
    Hey Jeremy,
    I thought for sure it was your htaccess file.
    I would like to get in and take a look.
    Please be on the lookout for an email from EllisLab.
