Calendar: Any way to limit entries to first entry per day?
October 10, 2012 2:22pm
  • #1 / Oct 10, 2012 2:22pm
    Susan
    I’m working on an event calendar.
    1 day of each month has two events. All other events are 1/day.
    Is there any way in the calendar to display only the first entry of a day in which there are multiple entries?
    (This isn’t a matter of if entries link to the entries for that day. I need to do an embedded template to grab the entry category and pass that to style for the TD for that day)
    If I loop the entries outside of the TD tags (see example below), EE will duplicate the cells for that day, resulting in 8 days a week.
    {if entries}
          {entries}
              <td class='{switch} {embed="embeds/code/goes/here"}'>
                    <a href="http://{day_path=channel/index}">{day_number}</a>
                    <div>
                        <a href="http://{title_permalink=channel/index}">{title}</a>
                    </div>
                </td>
          {/entries}
    I’d rather get just the first entry for that day and ignore subsequent entries for that day.
  • #2 / Oct 12, 2012 1:55pm
    Kevin Smith
    Hi Susan,
    It appears the {entries} variable pair does not have the ability to limit the number of entries returned. That would certainly make for a good Feature Request if you’d like to add it.
    I do wish I had a better solution for you here!
