Video works when I am using Firefox, but when i use IE8 all I get is a black screen and sound.
October 10, 2012 8:46am
Subscribe [2]#1 / Oct 10, 2012 8:46am
#2 / Oct 12, 2012 10:37am
Hello Briannorwood,
This is unrelated to ExpressionEngine, it’s probably the way the embed is coded. Even though it has nothing to do with ExpressionEngine, if you want to paste in your code I can take a look and see if I spot anything.
Cheers!
#3 / Oct 15, 2012 10:33pm
<style type="text/css" media="screen">
div.intro {min-height:0; height:auto !important;}
div.intro h2, div.intro p {margin-left:0;}
</style>
<div id="main">
div.mejs-container, video, embed, object {max-width:100%;}
</style>
[removed][removed]
<link href="http://50.56.204.23/mediaelement/mediaelementplayer.min.css" rel="stylesheet" type="text/css" />
<h1>Are You Ready</h1>
<video src="http://50.56.204.23//videos/Secure/Are_you_ready.m4v" autobuffer controls></video>
<a href="http://50.56.204.23//videos/Secure/Are_you_ready.m4v">Right-click to download</a>
[removed]
// jQuery method
$('video').mediaelementplayer();
[removed]#4 / Oct 17, 2012 9:11am
It’s stripping out the JS due to security filters. As Shane notes- this is really unlikely to be an EE specific issue. Here’s what I’d do to figure it out. Put the video on a plan html page completely outside of EE. Does it work? If not- debug there until it works. This doesn’t look like a youtube embed or something- are you using your own player? Check those forums/FAQs/Docs- odds are really really good this has happened to someone else.
If it DOES work in the html, stick it all, hard coded, into a template. Does it still work? It should, unless somehow a path is wrong or something.
Once it works hard coded into a template? Time to make it dynamic- and use tags to output the path to the m4v and any titles, etc. Again- do this on a simplified template. If it doesn’t work dynamically- compare the source of that page to the working hard coded template. That will make it easy to see the differences.
Make sense?
