can not upload image more than 200k
October 08, 2012 9:22am
  • #1 / Oct 08, 2012 9:22am
    Jasper Kooij
    I have a problem with uploading images larger than 200k and I do not understand why.
    Here is my setup:
    *fresh install of expression engine 2.5.3
    *removed index.php as my homepage and updated the .htaccess:
    <IfModule mod_rewrite.c>
             RewriteEngine On
             # Removes index.php from ExpressionEngine URLs
     </IfModule>
    *had GD installed :
    gd
    GD Support enabled
    GD Version bundled (2.0.34 compatible)
    *created a directory for images /uploads/slider_images
    *gave it 777 permission
    * “Image Resizing Protocol” is set for GD 2 in the Image Resizing Preferences
    * in the file upload preferences I have the entries for the location:
    /home/********/public_html/uploads/slider_images/
    and
    http://domainname/uploads/slider_images/
    * the file type in the preferences is images only.
    PHP settings are:
    post_max_size 8M 8M
    memory_limit 32M 32M
    upload_max_filesize 2M 2M
    I have a dedicated server with WHM/Cpanel with Apache/2.2.23 and php 5.3.17.
    Yet when I upload an image over about 200k, the homepage appears in the upload window as you can see in the attached screenshot.
    How can I make this work?
  • #2 / Oct 08, 2012 5:39pm
    Shane Eckert
    Hey there adlitinc,
    This is really interesting. I imagine some error is being hit and you are getting a 404, which takes you to the homepage by default if you have not yet setup a 404 page.
    I would like to take a look at this one.
    Please be on the lookout for an email from EllisLab.
    Cheers!
  • #3 / Oct 11, 2012 5:45pm
    Dan Decker
    Just to update the thread. This issue was related to PHP memory limit.
    Upping PHP’s allowed memory got everything running smoothly.
    Cheers!
  • #4 / Oct 11, 2012 5:49pm
    Jasper Kooij
    Yes, That did the trick.
  • #5 / Oct 12, 2012 4:14pm
    Shane Eckert
    Hey all,
    Closing off the thread. Glad that Dan was able to help you get to the bottom of the issue Jasper.
