Reset auto increment URL
October 04, 2012 8:23am
  • #1 / Oct 04, 2012 8:23am
    amityweb
    Hi
    I have been experimenting with importing over 5000 records into a channel entry. I have had to do this a number if times.
    It means the first entry ID is like 15000
    I know it probably does not matter that much, but I do like to be clean and tidy. I want to reset this back, I know how to do it in Phpmyadmin but wondered if anyone knows if any other tables will reference it. If its a couple of tables, fine, if its loads then it could be an issue!
  • #2 / Oct 05, 2012 4:51pm
    Dan Decker
    Hi amityweb,
    Everything start with exp_channel_titles - you can delete all of the entries in the Control Panel, then TRUNCATE exp_channel_titles and it will reset entry ID at 1.
    Let me know if you have any questions!
  • #3 / Oct 05, 2012 5:27pm
    amityweb
    thanks a lot I will give it a go (after a db backup of course!). I am up to about 30000 now! Although I dont think I need to import again after this.
  • #4 / Oct 08, 2012 12:57pm
    Shane Eckert
    Hi amityweb,
    Did you get a chance to try this? How is it going?
