Hi guys, just started using EE more and more and moving somewhat away from full CI builds. The one issue I seem to be running into over and over is working with repo’s and updating a site. I currently work all offline and push my changes live. I find that if I’m working on a few templates and push them live there seems to be all sorts of issues with synchronizing etc. to the point that it doesn’t even recognize the new templates. I found the only way I can edit templates locally and push them to the live site is to also push the local db with it. This seems ridiculous to do and right now the only way I can see this working is pulling down the live db, importing it locally, doing your template changes then pushing them all live while changing template and site paths both times. So my question is…
Am I crazy? Is there a better way to do this? I need something that’s a lot easier than all that. What am I missing? Thanks guys!
