Calling a Segment inside exp:query
October 03, 2012 1:35pm
  • #1 / Oct 03, 2012 1:35pm
    ovation01
    Hello,
    We are upgrading to EE1 from EE1.6.9.  The query plugin statement below used to work just fine, but now I can’t get it to render the “segment” variables within the exp:query tags. If I remove the segment variables and just search for specific hard-coded data, the query outputs just fine.  Problem is I need this query to be dynamic, pulling from the URL.
    Is my formatting off?  Other ideas?
    {exp:query sql="SELECT group_id, member_id, join_date, username FROM exp_members WHERE username = '{segment_3}' AND join_date = '{segment_4}' "}
    Congrats, you have access, {username}!
    {/exp:query}
    Thank you!
  • #2 / Oct 03, 2012 1:47pm
    mark186282
    (removed on purpose… the following comment gives a much better solution to the original problem)
  • #3 / Oct 03, 2012 1:49pm
    ovation01
    UPDATE:
    OK I got the line to render by removing the spaces. IE.
    is now
    username='{segment_3}'
    NEW PROBLEM:
    It seems the exp:query plugin cannot search for a user by his join_date. It CAN output the join_date, but when join_date is used as a search criteria it fails.
    So, this line works:
    {exp:query sql="SELECT group_id, member_id, join_date, username FROM exp_members WHERE username='testuser' "}
    But this line below doesn’t render—any ideas?
    {exp:query sql="SELECT group_id, member_id, join_date, username FROM exp_members WHERE join_date='123456789' "}
  • #4 / Oct 03, 2012 1:58pm
    mark186282
    what are you using as a source for your join_date?
    Remember that the join_date is stored in unix timestamp format, and is the specific to the second (not just the date) of the member joining.
    If you are looking for the match of somebody joining that day, you could calculate the range and query accordingly…
  • #5 / Oct 03, 2012 2:04pm
    ovation01
    Thanks for the replies - I realized I was testing with an out-of-date variable that has since changed. The above code (in my 2nd post) is working now. Thank you and please close this thread.
  • #6 / Oct 05, 2012 10:35am
    Shane Eckert
    Hello ovation,
    I am glad you got this worked out! Thanks for the help here Mark!
