Here’s an odd one. I have 3 upload directories working fine. Just added another but I get the"upload path does not appear to be valid” error when trying to upload to it via File Manager. Permissions set to 775 (tried 777 too).
Path and URL are fine. Only difference from previous 3 upload directories are that they sit within an /assets/uploads/ folder, and this one is in the root (/technical-specs/). The path is perfect (/home/mydomain/public_html/technical-specs/) and it’s not permissions. Anything else I can check?
Interestingly, if I FTP a file into technical-spec I can see Number of Files as 1 in Synchronize Directory, and it syncs with no errors. Then if I go to File Manager > Filter by Directory > Technical Specs I get “You have no files uploaded to this directory.”
