Splitting Channel Fields
October 02, 2012 12:43am
  • #1 / Oct 02, 2012 12:43am
    areichert
    I currently have over 270 channel fields in my database, and I’m having issues with ExpressionEngine. Specifically, when I try to add additional fields, performance is terrible and I start to get 500 Internal Server errors.
    I looked at the channel_data table and noticed that I have 2 columns for each field, creating over 540 columns. Is there a way to split this into multiple tables. As of right now, I’m just trying to get the back end to work. When I go to publish or edit a channel entry for a channel that has over 100 fields, it times out. I increased the memory_limit and max_execution_time, but no dice.
    Let me know if there is a way to break this up into multiple tables, or perhaps I could break it into multiple tabs and the tabs would only load once clicked. Thoughts?
    Thanks in advance,
    Andrew
  • #2 / Oct 03, 2012 12:10pm
    Dan Decker
    Hi Andrew,
    Thank you for posting to the Forums and welcome!
    I’m sorry you’ve run into this.
    Not without some serious mods to the Core of ExpressionEngine. The way channels and fields are handled runs pretty deep.
    One thing you can do is implement Pixel & Tonic’s Matrix. Matrix stores its data in a separate table and counts as only one field in and of itself. It would be a rebuild for the most part, but would help spread the load.
    I’m sorry, but I don’t have an answer that doesn’t involve a good bit of work :(
    If the Matrix idea sounds like something you would like to investigate, let me know and we can walk it out.
  • #3 / Oct 04, 2012 10:52am
    areichert
    Hi Dan,
    Thanks for the response.
    As it turns out, Matrix is actually installed and part of the problem. I get the 500 internal server error when adding a Matrix field with a Playa field inside. It works when I create up to 4 Matrix entries, but then I get the server error whenever I go up to about 10 entries.
    I understand that you are unlikely to provide any support for third-party add-ons (I have been working with P&T, but no solution so far), so figured I’d try another route (such as splitting up the channel_data table. If you have any other thoughts, let me know.
    Andrew
  • #4 / Oct 05, 2012 3:01pm
    Dan Decker
    Hey Andrew,
    What version of ExpressionEngine, Matrix and Playa are you using?
    I check for compatibility if you’d like.
  • #5 / Oct 05, 2012 4:49pm
    areichert
    EE v2.5.2
    Playa v4.1.0.3
    Matrix v2.4.3
    Andrew
  • #6 / Oct 07, 2012 10:44pm
    areichert
    Dan,
    While you’re checking into compatibility, I asked my hosting company to look into it as well and they said that the error log showed the following:
    [Sun Oct 07 21:18:40 2012] [error] [client 46.214.130.40] Warning: PHP Startup: It is not safe to rely on the system’s timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected ‘America/Chicago’ for ‘CDT/-5.0/DST’ instead in Unknown on line 0, referer: http://test.gofinancialaid.com/admin.php?S=e4796b24d5fd665c6a600cda7855b94387234292&D=cp&C=content_edit&channel_id=8
    [Sun Oct 07 21:18:40 2012] [error] [client 46.214.130.40] , referer: http://test.gofinancialaid.com/admin.php?S=e4796b24d5fd665c6a600cda7855b94387234292&D=cp&C=content_edit&channel_id=8
    [Sun Oct 07 21:18:40 2012] [error] [client 46.214.130.40] Deprecated: Directive ‘magic_quotes_gpc’ is deprecated in PHP 5.3 and greater in Unknown on line 0, referer: http://test.gofinancialaid.com/admin.php?S=e4796b24d5fd665c6a600cda7855b94387234292&D=cp&C=content_edit&channel_id=8
    Let me know if this means anything to you.
    Andrew
  • #7 / Oct 08, 2012 12:48pm
    Shane Eckert
    Hey Andrew,
    Any work from P&T? The error from the log does not really point out what is calling the deprecated call.
    Thank you,
  • #8 / Oct 08, 2012 12:56pm
    airways
    It looks like your version of Playa is a bit out of date. I would recommend upgrading Playa since P&T’s addons like to be in sync with each other - you should always use the version of both that were available on the website at the same time and you should upgrade them both at the same time.
    The latest version of Playa is 4.3.3, which should go along with the version of Matrix you have - 2.4.3 - which is also the latests.
    Before upgrading anything, do a full site backup. You may also want to open a Matrix support request with P&T.
  • #9 / Oct 08, 2012 9:37pm
    areichert
    Thanks, all. I upgraded to Playa 4.3.3 and EE 2.5.3 and still no luck.
    I was communicating directly with Brandon by email, but maybe I’ll move that discussion to the P&T support forums to see if anyone else has this issue.
    Let me know if you guys think of anything within EE that might help.
    Thanks again,
    Andrew
  • #10 / Oct 09, 2012 11:40am
    Shane Eckert
    Hey Andrew,
    Will do!
