just to point that your (official) instructions to upgrade Forum, there is not a mention to upload the “forum themes”...
October 01, 2012 1:06am
Subscribe [1]#1 / Oct 01, 2012 1:06am
#2 / Oct 02, 2012 10:55am
Hey deschamps,
I hope you week is going well!
Are you referring to this guide?
Step 2 talks about uploading the forum folder to the right location, which includes the themes folder.
Would you like it to be made more clear? I can submit that request for you if you think it’s no clear.
Thank you,
#3 / Oct 02, 2012 10:27pm
yes, I am referring to that guide…
the “forum” folder goes to “system/expressionengine/modules/”...
and the “forum_themes” go to “themes/”... which is at the same level than “system”...
this last step is not mentioned…
saludos
#4 / Oct 04, 2012 10:12am
Hi deschamps,
Understood. I think it may be an oversight because it is listed in the install documentation.
I will make sure that addition makes it to the docs.
Is there anything else I can help with?
Thank you,
#5 / Oct 04, 2012 12:41pm
oh, ok, I did not see that, but found the other reference… ...
thanks Shane… ... saludos
#6 / Oct 05, 2012 1:53pm
Hey deschamps,
Awesome. Have a great Friday and a great weekend!
