Wrong style path for control panel
September 25, 2012 11:24am
  • #1 / Sep 25, 2012 11:24am
    jiri.tobolka
    Hello,
    I can’t see the css style in control panel. What I see is wrong path to CSS stylesheet in HTML header:
    http://new-developer.gooddata.com/themes/site_themescp_themes/default/css/global.css?v=1312191758
    which is wrong because of the missing slash…should be
    http://new-developer.gooddata.com/themes/site_themes/cp_themes/default/css/global.css?v=1312191758
    I cannot find the way how to change it. Basically this starting to appear after I changed the theme path to correct location that is “/www/eh17632/public_html/themes/”
    Can you please help me with this? I don’t understand this behavior.
    Thanks a lot! Regards,
    JT
  • #2 / Sep 26, 2012 11:01am
    Dan Decker
    Hi JT,
    I’m sorry you’ve run into this trouble!
    The path is one thing to check, but themes also require a valid URL.
    In Admin-> General Configuration, make sure both path and URL for Themes is set properly.
    What version of ExpressionEngine are you using?
  • #3 / Sep 26, 2012 11:06am
    jiri.tobolka
    Hi! Thanks for your response. My version is EE 2.2.2 and I think have the correct paths… Do you have any other idea? Because running back-end without style is not so comfortable…
    Thank you for your advice!
    JT
  • #4 / Sep 26, 2012 11:53am
    madebycloud
    Quick suggestion. Have you set this anywhere in your config.php file?
  • #5 / Sep 27, 2012 11:45am
    Kevin Smith
    Hey JT,
    I think we can solve this pretty quickly with a first-hand look. Be on the lookout for an email from me!
  • #6 / Oct 01, 2012 8:34am
    jiri.tobolka
    Hi Kevin!
    Thank you for your information. I’ve sent you all requested things via email. I hope the solution will be fast and easy.
    JT
  • #7 / Oct 02, 2012 9:53am
    Dan Decker
    Hi JT,
    Just confirming that we have your details and will be following up with you in email. Once we have a resolution, we’ll post back here to update the thread.
    Cheers!
  • #8 / Oct 02, 2012 10:03am
    jiri.tobolka
    Cool, thanks!
  • #9 / Oct 03, 2012 11:16am
    Kevin Smith
    Got Jiri taken care of here. The problem was that the URL to the “themes” folder wasn’t set correctly in the CP. Looks like it had “site_themes” added to the end of it, which wasn’t necessary.
    If anyone else is having similar issues, please open up a new thread and we’ll be glad to help.
