When updating from EE 2.1.1 to 2.5.3 (using FF 15.0.1) I get the following error:
A Database Error Occurred
Error Number: 1060
Duplicate column name ‘show_sidebar’
ALTER TABLE exp_members ADD show_sidebar char(1) NOT NULL default ‘y’ AFTER quick_tabs
Filename: updates/ud_212.php
Line Number: 53
This has been encountered by others, and I followed their suggestions and commented out this instruction in updates/ud_212.php (actually line 37).
I cleared and then restored the database and re-ran the installation.
This time it got as far as the following:
Error Number: 1054
Unknown column ‘show_sidebar’ in ‘exp_members’
ALTER TABLE exp_members ALTER COLUMN show_sidebar SET DEFAULT ‘n’
Filename: updates/ud_220.php
Line Number: 217
What do I do now?
Frankly I find it amazing that a problem that has been encountered so frequently has not been dealt with and solved. It is fairly normal procedure to only update occasionally (given the frequency of your updates).
It is also frustrating that in all the many instances in this forum in which people have encountered this problem nobody from Ellis Labs has seen fit to provide an explanation…
Others who have suffered the same fate:
http://ellislab.com/forums/viewthread/222862/
http://ellislab.com/forums/viewthread/222600/
http://ellislab.com/forums/viewthread/202108/
http://ellislab.com/forums/viewthread/194783/
regards
Chris
