Hey
Just went thought a smooth 1.7.x -> 2.5.3 upgrade… however I am unable to get anything other than the sites default index page to render.
I have removed all templates, saved new templates as files. The files update OK from file -> DB
I have tried with and without .htaccess.
I have attached a screenshot of the template debugger and it doesn’t appear to be seeing the URI to pull the correct template.
Any ideas what I should try next?
