Errors when duplicating channel and entries
September 11, 2012 9:23am
  • #1 / Sep 11, 2012 9:23am
    Tom
    I’m getting a database error on an EE v2.4.0 site when creating a new site and copying data across from an existing one.
    Steps I’m taking:
    1. Site Management > Create new site
    2. Using ‘duplicate channel, duplicate entries’ on the items I wish to copy across. Some others are set to ‘do nothing’ if the site I’m creating doesn’t need that data.
    3. The following errors occur:
    A PHP Error was encountered
    Severity: Notice
    Message: Undefined index: 571
    Filename: cp/sites.php
    Line Number: 744
    A Database Error Occurred
    Error Number: 1048
    Column 'entry_id' cannot be null
    INSERT INTO `exp_channel_data` (`entry_id`, `site_id`, `channel_id`, `field_id_2`, `field_ft_2`, `field_id_3`, `field_ft_3`, `field_id_4`, `field_ft_4`, `field_id_5`, `field_ft_5`, `field_id_6`, `field_ft_6`, `field_id_7`, `field_ft_7`, `field_id_8`, `field_ft_8`, `field_id_9`, `field_ft_9`, `field_id_10`, `field_ft_10`, `field_id_11`, `field_ft_11`, `field_id_12`, `field_ft_12`, `field_id_13`, `field_dt_13`, `field_ft_13`, `field_id_14`, `field_ft_14`, `field_id_19`, `field_ft_19`, `field_id_20`, `field_ft_20`, `field_id_21`, `field_ft_21`, `field_id_28`, `field_ft_28`, `field_id_29`, `field_ft_29`, `field_id_30`, `field_ft_30`, `field_id_31`, `field_ft_31`, `field_id_32`, `field_ft_32`, `field_id_33`, `field_ft_33`, `field_id_34`, `field_ft_34`, `field_id_35`, `field_ft_35`, `field_id_36`, `field_ft_36`, `field_id_37`, `field_ft_37`, `field_id_38`, `field_ft_38`, `field_id_39`, `field_ft_39`, `field_id_40`, `field_ft_40`, `field_id_41`, `field_ft_41`, `field_id_51`, `field_ft_51`, `field_id_52`, `field_ft_52`, `field_id_53`, `field_ft_53`, `field_id_54`, `field_ft_54`, `field_id_55`, `field_ft_55`, `field_id_56`, `field_ft_56`, `field_id_57`, `field_ft_57`, `field_id_58`, `field_ft_58`, `field_id_59`, `field_ft_59`, `field_id_60`, `field_ft_60`, `field_id_61`, `field_ft_61`, `field_id_62`, `field_ft_62`, `field_id_63`, `field_ft_63`, `field_id_64`, `field_ft_64`, `field_id_65`, `field_ft_65`, `field_id_66`, `field_ft_66`, `field_id_67`, `field_ft_67`, `field_id_68`, `field_ft_68`, `field_id_69`, `field_ft_69`, `field_id_70`, `field_ft_70`, `field_id_71`, `field_ft_71`, `field_id_74`, `field_ft_74`, `field_id_75`, `field_ft_75`, `field_id_78`, `field_ft_78`, `field_id_80`, `field_ft_80`, `field_id_81`, `field_ft_81`, `field_id_83`, `field_ft_83`, `field_id_84`, `field_ft_84`, `field_id_86`, `field_ft_86`, `field_id_87`, `field_ft_87`, `field_id_89`, `field_ft_89`, `field_id_90`, `field_ft_90`, `field_id_91`, `field_ft_91`, `field_id_92`, `field_ft_92`, `field_id_93`, `field_ft_93`, `field_id_94`, `field_ft_94`, `field_id_95`, `field_ft_95`, `field_id_96`, `field_ft_96`, `field_id_97`, `field_ft_97`, `field_id_98`, `field_ft_98`, `field_id_99`, `field_ft_99`, `field_id_100`, `field_ft_100`, `field_id_101`, `field_ft_101`, `field_id_102`, `field_ft_102`, `field_id_104`, `field_ft_104`, `field_id_105`, `field_ft_105`, `field_id_106`, `field_ft_106`, `field_id_107`, `field_ft_107`, `field_id_108`, `field_ft_108`, `field_id_109`, `field_ft_109`, `field_id_110`, `field_ft_110`, `field_id_111`, `field_ft_111`, `field_id_112`, `field_ft_112`, `field_id_113`, `field_ft_113`, `field_id_114`, `field_ft_114`, `field_id_115`, `field_ft_115`, `field_id_116`, `field_ft_116`, `field_id_117`, `field_ft_117`, `field_id_118`, `field_ft_118`, `field_id_119`, `field_ft_119`, `field_id_121`, `field_ft_121`, `field_id_122`, `field_ft_122`, `field_id_123`, `field_ft_123`, `field_id_124`, `field_ft_124`, `field_id_125`, `field_ft_125`, `field_id_126`, `field_ft_126`, `field_id_127`, `field_ft_127`, `field_id_128`, `field_ft_128`, `field_id_129`, `field_ft_129`, `field_id_130`, `field_ft_130`, `field_id_134`, `field_ft_134`, `field_id_135`, `field_ft_135`, `field_id_136`, `field_ft_136`, `field_id_137`, `field_ft_137`, `field_id_138`, `field_ft_138`, `field_id_139`, `field_ft_139`, `field_id_140`, `field_ft_140`) VALUES (NULL, 16, 105, '', NULL, '', NULL, '', NULL, '0', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '0', NULL, NULL, '', NULL, '', NULL, '', NULL, '', NULL, 'xxx', 'br', 'VPA No: 10999/129/003', 'none', 'Each light brown tablet contains:\nCarprofen 100mg', 'br', '', 'br', '', 'br', '', NULL, '', NULL, '', NULL, '', NULL, '', 'xhtml', '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '0', NULL, '', NULL, '0', NULL, '', NULL, '0', NULL, '', NULL, '0', NULL, '', NULL, '', 'xhtml', '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', NULL, '', 'xhtml', '0', 'none', '0', 'none', '0', 'none', '0', 'none', '0', 'none', '0', 'none', '0', 'none', '0', 'none', '0', 'none', '', 'xhtml', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'br', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'xhtml')
    Filename: controllers/cp/sites.php
    Line Number: 747
    Please can anyone advise why this error may be occuring? I examined the database and noticed ‘entry_id’ is not an auto_increment field, but I believe this is correct anyway since the same is true on both the live and development versions of the site we’re working on.
    Any help would be appreciated.
    I should also mention that the new site is actually created even though this error occurs, in other words the new site appears on the top right-hand menu in the EE Admin. But not all of the data selected gets copied across.
    Andy
  • #2 / Sep 12, 2012 11:55am
    Dan Decker
    Hi Ŧom,
    That’s a lot of channel fields - It may be best to get a look at this first hand. Be on the lookout for an email from EllisLab.
