speeding up the site
September 08, 2012 8:24pm
Subscribe [4]
  • #1 / Sep 08, 2012 8:24pm
    bthom62
    I read online that one of the steps to speeding up expression engine, is to disable/uninstall some of the modules
    I have identified 5 of them
    1. referer-  (never use it)
    2. search—never use it—use google search)
    3. statistics (never used them—use google analytics
    4. e-mail (we use no contact forms) but do show the email link of the members’ articles and columns
    5. emoticon (we have comments, but do not allow emoticons)
    can we uninstall
    are there benefits
  • #2 / Sep 08, 2012 8:35pm
    sdeley
    we host our site on media temple and found it was running way too slow on the basic service with shared SQL. our solution was to go with a gridcontainer which basically allocated reserved bandwith on the SQL server. totally sped up our site by a factor of 5x
  • #3 / Sep 08, 2012 11:41pm
    Enviromed
    You definitely can uninstall the modules you listed.
    general reference guide on ee performance:
    http://www2.grist.org/misc/Performance_Guidelines.pdf
    Good luck!
  • #4 / Sep 10, 2012 12:52pm
    Shane Eckert
    Hey there bthom62,
    Thank you for asking your question here in the ExpressionEngine forum! Glad to have you here.
    Looks like you have some good ideas here.
    Can I ask, what prompted the need for performance tuning? Are you seeing some slow downs? If so, where are you seeing those and have you used template debugging and the profiler to pinpoint that?
    If the slow down is a real issue, these suggestions will help. You might also consider standing up a Varnish Server in front of your site.
    Just some more ideas.
    Please let me know if there is anything else I can help with!
  • #5 / Sep 10, 2012 6:50pm
    bthom62
    Hi Shane
    Thank you
    Since we last talked, we have upgraded to 2.4. have set up a CDN account to handle our static content
    We have set up caching ( stuff with headers and the htaccess and expiry dates)
    Moved to a bigger server
    Cleaned up our templates
    The net result is that we are no longer using 100+ % of our database usage.
    However, the site on occasion is still slowing up.
    We have to find a way to make our site more secure on its uptime
    template debugger is showing me noting
    No Idea what a varnish server is
  • #6 / Sep 11, 2012 3:09pm
    Shane Eckert
    Hey bthom62,
    Wow, lots of changes! Sounds like fun geekery.
    Varnish is a caching server that cuts down on redundant requests. (gross over simplification) The article I link to talks about it.
    Is there anything else I can do to help?
    Thank you,
