{filedir_X} in Channel Entries not parsing?
September 06, 2012 2:07pm
  • #1 / Sep 06, 2012 2:07pm
    Adam Christianson
    I’m having almost this exact same issue, yet I’m inserting a {fieldir_X} tag directly inside a channel entries tag and it’s not parsing at all.
  • #2 / Sep 07, 2012 5:07pm
    Kevin Smith
    Hi Adam,
    I think that’s actually a different bug they were experiencing in that thread, and it’s since been fixed. (Speaking of, which version EE are you running here?)
    Could you give us a quick code sample of what you’re trying which a screenshot of how it looks on the front-end?
  • #3 / Sep 07, 2012 8:24pm
    Adam Christianson
    This could be user error. I’m running EE 2.5.2 and I’m just trying to just output the https://ellislab.com/asset/images/team-photo/ tag directly in a channel entry loop to debug the output. i.e.
    {exp:channel:entries site="tmo" status="open" limit="10" }
    Or will that tag only parse if it’s part of a custom tag with the file field type?
    The real bug I was tracking down was actually an issue with the tag not being parsed inside Solspace’s Primary Category which has a {primary_category_image} tag which outputs the file for the category image. It was in trying to test that that I attempted to just dump out the {fieldir} tag in the CE loop.
    http://www.solspace.com/forums/viewthread/13508/#55174
  • #4 / Sep 11, 2012 10:30am
    Dan Decker
    Hey Adam,
    Right. The fieldir_x variables aren’t parsed outside the context of a file field or perhaps a text/textarea that holds that value.
    You might be interested in using the FIle Module to get that output?
  • #5 / Sep 11, 2012 11:07am
    Adam Christianson
    I figured it was probably my mistake. Actually, I was just trying to use it outside the file field context for debugging the issue I was noticing with Primary Category, so now that I know that’s a Primary Category bug I just need to wait for the fix. Thanks as always for the response.
  • #6 / Sep 12, 2012 9:45am
    Dan Decker
    Hey Adam,
    It’s my pleasure to be here for you.
    If you need anything else, please let us know!
