Auto URL Linking Weirdness
September 05, 2012 12:38pm
  • #1 / Sep 05, 2012 12:38pm
    ParisJC
    I have “Automatically turn URLs and email addresses into links” turned on. In the past (v1.x days) there once was a problem with using punctuation before and after URLs and adresses. But now I’ve found an anomaly in v2.5.2. Maybe. Though the links themselves are created correctly.
    I have formatting set to none in the body field. When I insert:
     ... <a href="http://www.domain.com">http://www.domain.com</a>.
    The output is:
    Note the period moved outside the closing paragraph code.
    I worked around this by inserting a space between the URL and the period. I notice it, but users probably won’t.
    When a comma was used after the URL:
     ... <a href="http://www.domain.com">http://www.domain.com</a>, and by the ... .
    The output was:
     ... <a href="http://www.domain.com">http://www.domain.com</a> and b,y the ... .
    Note how the comma jumped several spaces to the right. I just deleted the comma to make the problem go away (after thinking I was crazy for not finding that extra comma).
    Bug with the way auto URLs are treated with formatting turned off?
  • #2 / Sep 07, 2012 10:57am
    Dan Decker
    Hi ParisJC,
    Thanks for bringing this to our attention!
    I was able to reproduce the output weirdness, so I filed a bug report. I went ahead and marked it as a show-stopper since it affects content output.
  • #3 / Sep 07, 2012 11:06am
    ParisJC
    I’m good to go with everything else so far, Dan. Glad you were able to replicate the problem.
    Thanks for filing the bug report!
  • #4 / Sep 10, 2012 2:14pm
    Dan Decker
    Hi ParisJC,
    However odd it sounds, I’m glad I was able to replicate too. Bug we can fix!
    If you need anything else, please let us know!
