I’m trying to figure out the most user friendly approach to the Pages module without using any plugins (Structure etc).
Wrapping my head around it, Pages require a channel to post in and assigned a template using at least one of the channel fields in the channel for any content to display on the page, correct? I assume so..
Onwards..
Approach 1
*Fit all page templates in one channel
*Create a channel and channel fields called “Page”
*Then create a template group called “pages” and place all templates there
*Inform your client that they must choose a template from the pages template group when creating a “Page”
The problem with approach 1 is that in the event of the templates differing in a sense where “template A” only uses half of the channel fields in the channel, and “template B” uses the remaining (different) fields: all the fields will display on the publish page regardless of which template the user is using, thus causing confusion in regard to which fields to use.
Approach 2
* Create a separate channel, channel fields, template group and template for each kind of template on the page
The problem with approach 2 is that it can create a lot of channels and groups (etc), becoming messy that way.
So.. have I missed the point completely, or is my understanding of how to deal with Pages up to par? If I have overlooked anything, which is highly possible considering I started learning about pages yesterday, I really appreciate some input.
Regarding which of the two approaches is most reasonable I guess that comes down to the individual requirements of the site, client and what not. Basically what I’m asking: Are my approaches reasonable ways of doing things without relying on a third party addon?
