Hi there,
Im trying to find a more elegant way to do the below - with php most likely. Im displaying my results in a royalslider, 9 entries per slide. I’d prefer not to avoid the hard coded approach below, so I was trying to find a way to iterate a variable and reset it every 9 results, but I wasnt having much luck.
Any insight/help would be much appreciated.
Kevin
{exp:channel:entries channel="channel_name" limit="90" sort="asc" disable="member_data|trackbacks"}
{if count == '1' OR count == '10' OR count == '19' OR count == '28' OR count == '37' OR count == '46' OR count == '55' OR count == '64' OR count == '73' OR count == '82' }
<li class="royalSlide">
<div class="centeredSlide clearfix">
<div class="item">
<a href="http://{path=lorem/ipsum/detail/{url_title}}">_{exp:ce_img:pair src="{preview_image:url}" width="116" height="110" crop="yes"}{made}{/exp:ce_img:pair}_ </a>
<div class="copy">
{media_type}
<h4><a href="http://{path=lorem/ipsum/detail/{url_title}}">{title} <?php echo($read_count); ?></a></h4>
<p> </div> <br />
</div> <br />
{if count == '9' OR count == '18' OR count == '27' OR count == '36' OR count == '45' OR count == '54' OR count == '63' OR count == '72' OR count == '82' OR count == '90' }<br />
</div><br />
</li><br />
{if:elseif count == total_results} <br />
</div><br />
</li><br />
