Need Help Understanding Related Entries Syntax
August 25, 2012 10:50am
  • #1 / Aug 25, 2012 10:50am
    Ed Hebert
    Hi-
    I don’t often use related_entries functionality, but I need it now. I’ve read all the EE documentation, but I’m not getting the expected results from my templates. I’m banging my head against a wall trying to understand the logic / syntax.
    In short, I have a “products” channel with a relationship field from the same channel. This relationship allows a subproduct to be connected to a main product when appropriate. For example, “Louvered Interior Shutters” as a subproduct entry of the “Interior Shutters” entry (both of which are in the “Shutters” Channel.
    I want my template to test whether the current entry is a “parent” page. If so, show some of its relevant “parent page” fields, and then list links to the subordinate pages. If it’s not a parent page, then go ahead and show a different set of details of the page. I’m using the same template for both conditions.
    In the code I’ve created, nothing in the “if no_reverse_related_entries” conditional is being parsed. No custom fields, and not even fields like {title}. Those fields get sent as plain text, and render as “{title}” right on the page.
    Aside from the specific issues with the reverse_related_entries conditional, am I even approaching this the right way logically, or is there a cleaner, more intuitive solution?
    Thanks for your help.
    My products/index.html template looks like this:
    {exp:channel:entries channel="products"}
    {reverse_related_entries}
    <a href="http://{url_title_path=products}">{url_title}</a>  {!-- build some links to the subproduct pages if appropriate --}
    {if no_reverse_related_entries} {!-- its an end level page, so show a bunch of details --}
        <div class="span5">
            <h2 class="underline">{title}</h2>
            {page}
            {edit_this}
        </div>
        <div class="span6 offset1">
            <ul class="thumbnails">
                {exp:channel_images:images entry_id="{entry_id}"}
                    <li class="span2"><a href="http://{image:url:medium}" rel="group" title="{image:description}" class="thumbnail fancybox">{image:url:small}</a></li>
                {/exp:channel_images:images}
            </ul>
        </div>
    {/if}  {!-- no_reverse_related_entries --}
    {/reverse_related_entries}
  • #2 / Aug 26, 2012 8:26am
    Ed Hebert
    Specifically, it seems that nothing inside the {if no_reverse_related_entries} conditional gets parsed. Am I not allowed to use any EE variables or custom fields inside that conditional?
  • #3 / Aug 27, 2012 11:12am
    Rob Allen
    At a guess it may be related to parse order?
    Have you tried conditionals here?
    {if count >= 1}
    {if count == 0}
    No reverse related entries code
  • #4 / Aug 27, 2012 11:25am
    Ed Hebert
    Thanks, bluedreamer. I hadn’t tried that. I actually just used PHP to solve the problem, but next time I’ll try using a conditional with count.
  • #5 / Aug 27, 2012 11:55am
    Shane Eckert
    Hey guys,
    Nice work here. You guys are a great example of why the community here is so awesome.
