Communicate Module does not support {name} tag
August 18, 2012 9:20am
  • #1 / Aug 18, 2012 9:20am
    Nick Foxall
    I’ve read elsewhere that you can personalise emails in the Communicate Module by using the {name} field, as used in other system emails. So - assuming you’re sending to a member group - the outgoing message will be sent to “Dear John Doe”, “Dear Jane Doe” etc. according to the member’s screen name.
    However, I’m finding that this ONLY works if the email format is set to Plain Text. It won’t work for HTML formatted emails in the Communicate Module. Is this normal behaviour? Why is this not working? Seems like it should parse this one EE field, no matter what the text format of the email message…?
    Any ideas?
    Nik
  • #2 / Aug 20, 2012 1:31pm
    Shane Eckert
    Hello Nick,
    t
    Thank you for posting your question here on the ExpressionEngine forums.
    Can you tell me what version of ExpressionEngine you are currently using?
    I am on 2.5.2 and I cannot reproduce this.
    Thank you,
  • #3 / Aug 20, 2012 6:38pm
    Nick Foxall
    Hi Shane - Sorry, should have put that in before… 2.5.1 build 20120529
    Nik
  • #4 / Aug 21, 2012 3:39am
    Shane Eckert
    Hey Nick,
    Are you using a mail list in all your test cases are are you adding {name} to the text area as well?
  • #5 / Aug 21, 2012 7:39pm
    Nick Foxall
    Shane,
    No, I’m using a test member group, where each member has a filled-in screen name. I thought it was supposed to use the screen name in the {name} field?
    And I know this member group works, because I’m able to send out (and receive) personalised emails when using plain text emails.
    Nik
  • #6 / Aug 22, 2012 4:03pm
    Shane Eckert
    Hi Nick,
    I am still unable to reproduce this.
    I think we might need to login and take a look.
    Before that, can you see if upgrading to 2.5.2 fixes the issue?
    Thank you,
  • #7 / Aug 23, 2012 12:51am
    Nick Foxall
    Shane,
    Upgraded to 2.5.2 and tested again, but still experiencing the same issue: HTML emails coming through as “Dear {name}” with no personalisation.
    Nik
  • #8 / Aug 23, 2012 3:12pm
    Shane Eckert
    Hi Nick,
    Gah! No good!
    Please be on the look out for an email from EllisLab.
