is there a way to use pagination for random entries? if I just use orderby=“random” i get repeating entries.
August 16, 2012 7:16am
Subscribe [2]#1 / Aug 16, 2012 7:16am
#2 / Aug 17, 2012 1:09pm
Hello j0han,
Thank you for posting your question here on the ExpressionEngine forums.
Can you show me your template code?
#3 / Aug 17, 2012 3:40pm
Hi Shane,
this is what I’m using:
{exp:channel:entries channel="shops|ads" limit="20" disable="categories|member_data|trackbacks|category_fields" orderby="random" paginate="top"}
<h3><a href="/index.php/shops/shop/{url_title}">{title}</a></h3><p> <br />
<br />
{paginate}<br />
<div id="pagination"><br />
{pagination_links}<br />
</div><br />
{/paginate}<br />
{/exp:channel:entries}#4 / Aug 20, 2012 12:24pm
Hi, j0han,
This is true that pagination will not hold in memory what random entries it has shown, so you may get repeats. There is an existing feature request for a change to this behavior that you could add your voice to.
Unfortunately I do not have a solution for you now - a custom plugin might achieve your goals though.
