Upgraded to MSM 2.1.3 but site urls are set to default
August 09, 2012 1:01am
  • #1 / Aug 09, 2012 1:01am
    lebisol
    I just upgraded to EE 2.5.2 and MSM 2.1.3
    Odd thing is when I click on the ‘View Site’ in upper right corner it leads to default site. Second and third sites are accessible when I manually enter url. Each site/folder has index.php with the correct config settings:
    $system_path = '../system';
     $assign_to_config['site_name'] = 'name2';
     $assign_to_config['cp_url'] = 'http://www.mysite2.com/system/';
     $assign_to_config['site_url'] = 'http://www.mydomain2.com';
    Any ideas?
  • #2 / Aug 09, 2012 12:38pm
    Shane Eckert
    Hey lebisol,
    Have you updated your admin.php file as well?
    Here is an example of a working site.
    //CONFIG//
    $config['cp_url'] = "http://engine.dev/admin.php";
    $config['doc_url'] = "http://ellislab.com/expressionengine/user-guide/";
    $config['is_system_on'] = "y";
    $config['allow_extensions'] = "y";
    $config['site_label'] = "Test 23";
    $config['cookie_prefix'] = "";
    $config['multiple_sites_enabled'] = "y";
    index.php and admin.php site 1
    NO CHANGES
    index.php and admin.php site 2
    $assign_to_config['site_name']  = 'msm_test';
    $assign_to_config['cp_url'] = 'http://msm.dev/admin.php';
    $assign_to_config['site_url'] = 'http://msm.dev';
    --- admin ---
    I hope this helps.
    Thank you,
  • #3 / Aug 09, 2012 1:03pm
    lebisol
    Hi Shane,
    I thought use of ‘admin’ page is optional to hitting ‘system’ folder?!
    Anyhow, I added the ‘admin.php’ (difference from ‘index’ being there is no $assign_to_config[‘site_url’] variable defined) into ‘/public_html/site2/’ and the change made no difference in CP under ‘View Site’ link.
    Thanks again.
  • #4 / Aug 10, 2012 10:26am
    Shane Eckert
    Hey lebisol,
    You are correct, the admin is option as it’s there to allow login to the msm site. If you are using admin.php then you would need to edit the file, if you are not, then no worries!
    If the configuration files are good, then those paths should be good and the drop down for the sites should link just fine.
    When you click on the right hand corner, do you get a drop down with the other sites listed? Or is it just a link to the current site?
    If there is a list of other sites, what URL do you see when you hover over those links?
    Thank you,
  • #5 / Aug 10, 2012 11:18am
    lebisol
    Small change after implementing admin pages.
    Site 2 is now ok but the site 3 still the same issue.
    The drop down shows all sites with the correct short names but when I hover/click over 3rd site it shows/links to the site I am logged into - the default “site1.com” vs. expected “site3.com”.
    If I go to “site3.com/system” it redirects me to “site1.com/404” (as expected since there is no such folder) while if I type in “site3.com/admin.php” I am in CP with the same issue as above.
    Thanks again.
  • #6 / Aug 10, 2012 4:45pm
    Shane Eckert
    Hey lebisol,
    Can you show me the config files for the third site?
    Are they identical aside from hostname/domain as site 2?
    Thank you,
  • #7 / Aug 10, 2012 6:55pm
    lebisol
    Yap, just did copy/edit of index and admin just to eliminate doubt 😊
    Still nothing…
    Just to make sure:
    Default site (site1):
    index.php and admin.php site1
    NO CHANGES other than declaring my system path.
    site2 and site3 respectively
    $assign_to_config['site_name']  = 'site2';
    $assign_to_config['cp_url'] = 'http://site2.com/admin.php';
    $assign_to_config['site_url'] = 'http://site2.com';
    --- admin ---
  • #8 / Aug 13, 2012 2:57pm
    Dan Decker
    Hi lebisol,
    Have you made sure to enable the MSM in the Control Panel under General Configuration?
    Uploading the files is only part of the process, you have to tell ExpressionEngine to “turn on” multiple sites in the Control Panel as well.
    Double check that and let us know!
  • #9 / Aug 13, 2012 3:52pm
    lebisol
    Hi Dan,
    Sure, that setting was on but I did a quick ‘save’ and no love.
  • #10 / Aug 14, 2012 3:59pm
    Dan Decker
    Hi lebisol,
    I sent an email request for more information. I look forward to getting a look at this!
  • #11 / Aug 14, 2012 4:11pm
    lebisol
    Got it, responded.
    Thank you.
  • #12 / Aug 14, 2012 5:33pm
    Shane Eckert
    Hey lebisol and any onlookers,
    The base url in one of the sites was set incorrectly. Correcting that fixed the issue.
    All is well.
