Kicked Out from Control Panel
August 05, 2012 4:16pm
Subscribe [5]
  • #1 / Aug 05, 2012 4:16pm
    bertc
    I have this very annoying problem with my EE website. I get kicked out often from the control panel without a clear reason. So I have to re-log in to the CP each time this happens.
    I have no clue why. Sometimes it happens when I hit a submit button (with code loss as a consequence), sometimes when I go to the template manager.
    Sometimes I can work for half an hour without a problem and sometimes I get kicked out 3 times in five minutes.
    My settings in Admin > Security & Sessions
    - cookies only for CP session type
    - Require IP Address and User Agent for posting? = No
    Can somebody help?
  • #2 / Aug 06, 2012 3:23pm
    Kevin Smith
    Hi bertc,
    Let me get some info from you to help troubleshoot this:
    - Is this an MSM site?
    - Are you running the latest release of EE 2? (That’s EE 2.5.2)
    - Are you accessing this site from behind a proxy or firewall?
    - Are you on a mobile connection?
    - In which geographic region are you located?
  • #3 / Aug 09, 2012 2:18pm
    bertc
    Hi Kevin,
    here are my answers to your questions:
    - Is this an MSM site? -> if you mean a Multi Site Manger site: no, it is a developer license
    - Are you running the latest release of EE 2? (That’s EE 2.5.2) -> I bought this license about a month ago, so I guess this is the latest version?
    - Are you accessing this site from behind a proxy or firewall? -> not that I know of
    - Are you on a mobile connection? -> No
    - In which geographic region are you located? -> In Belgium (Europe)
    Best regards,
    Bert
  • #4 / Aug 10, 2012 10:44am
    Kevin Smith
    Hey Bert,
    I think the best way to help you here is to have a look myself. Be on the lookout for an email from me!
  • #5 / Aug 10, 2012 11:21am
    Heather Musil
    Hi Bert,
    I don’t know if this will help but I had a similar problem on one of my EE sites and what finally worked was to clear out all of my cookies and other saved internet files. I remember it was a very annoying problem, good luck!
    Heather
  • #6 / Aug 10, 2012 2:57pm
    Kevin Smith
    While we await your login information, Bert, does Heather’s suggestion help resolve this? Perhaps something just got stuck in the cache.
  • #7 / Aug 14, 2012 4:05am
    bertc
    I cleared the cookies, etc as Heather pointed out and apparently this helped for a while.
    But I just got kicked out again. So does anyone else have an idea how to solve this?
  • #8 / Aug 14, 2012 4:48pm
    gelviis
    Just to share; I had a similar issue. I had a load balancer installed in the office that switched between two different internet connections. When I removed the load balancer and plugged straight into one internet connection using a router the problem disappeared. So check whatever set up you have in your office. Have you tried logging in from different locations? Do you get the same result?
  • #9 / Aug 15, 2012 11:40am
    Dan Decker
    Hi Bert,
    Did Greg’s idea shed any light on your situation?
    If you IP rotates, it can invalidate your ExpressionEngine session/cookies. You can turn this off in Admin-> Security and Privacy-> Security and Sessions: Require IP Address and User Agent for Login?
  • #10 / Aug 16, 2012 12:10pm
    bertc
    Thanks for the help Greg, but unfortunately I connect directly to the internet via a router. So I guess this should not be causing the problem.
    Hi Dan, I will try this option and keep my fingers crossed.
  • #11 / Aug 16, 2012 12:22pm
    bertc
    Unfortunately turning off “Require IP Address and User Agent for Login” did not help either. In the last 5 minutes I got kicked out 2 times. This problem is driving me mad.
    I tried EE with the developer license to check out whether it would be a good CMS for my potential clients. But I am getting serious doubts.
    Anyone else an idea?
    ==> I just disabled “Save revisions” and I haven’t been kicked out the admin for an hour. Could this be the solution?
  • #12 / Aug 17, 2012 2:25pm
    Kevin Smith
    Hi Bert,
    Thanks for the note on saving revisions. Now that it’s been a little over a day since you posted that, have you found enabling/disabling that preference to provide any kind of consistent pattern?
  • #13 / Aug 17, 2012 6:02pm
    bertc
    Hi Kevin,
    unfortunately the problem is still not solved. However, I have the impression that I do not get kicked out that often.
  • #14 / Aug 18, 2012 8:23am
    bertc
    Can anyone tell me what is checked wether someone should be granted access to the control panel? If I know what is checked perhaps I can start looking there what might be causing this problem?
  • #15 / Aug 20, 2012 3:49pm
    Dan Decker
    Hey Bert,
    All Control Panel access options for a Member Group are set under the “Control Panel Access” header when you edit the Member group.
    Ultimately, I think this may have to do with session/cookie issues we’re tracking overall.
    Do you see the same behavior as a Super Admin?
