Retrieving member_id using PHP for non-control panel users
August 03, 2012 6:16am
  • #1 / Aug 03, 2012 6:16am
    eyekiller
    Hi all
    I have a module that requires a {member_id} before that variable is parsed (as the modules are parsed beforehand)... so I’ve used PHP, but I’ve found that the Session class only works for hose users who have logged in with the control panel…
    My users log in using a members login form, and I need to retrieve their {member_id} from the cookie so I can pass to this form…  all attempts have failed 😕
    any help with this would be greatly appreciated…
    many thanks in advance
  • #2 / Aug 03, 2012 6:48am
    Mike Bean
    Have you tried using logged_in_member_id instead of member_id?
  • #3 / Aug 03, 2012 7:07am
    eyekiller
    Hi Mike
    Yeah..  I tried that first.  The module I’m using (after a bit of debugging) was being passed the literal string “{logged_in_member_id}”...  also, if I use
    <?php echo $this->EE->session->userdata('logged_in_member_id'); ?>
    it returns a blank value
  • #4 / Aug 03, 2012 7:10am
    eyekiller
    if I look at my cookies I can see an exp_sessionid, which I understand, is the same id used in the control panel if I were to log in there…  is there any way of parsing that ID and retrieving the data without tearing strips out of the code (something I’d like to avoid)
  • #5 / Aug 03, 2012 7:43am
    eyekiller
    Nevermind… user error 😕
  • #6 / Aug 03, 2012 11:06am
    Hi, eyekiller - I just want to confirm that you did get this working?
    Thank you!
  • #7 / Aug 03, 2012 11:34am
    eyekiller
    Hey Lisa
    Yes, I got this working… the
    <?php echo $this->EE->session->userdata('member_id'); ?>
    worked.
  • #8 / Aug 03, 2012 12:06pm
    Awesome, very glad to hear it! If anything else comes up, please let us know, and have a wonderful weekend!
