page not found error when using Template Manager View Button
July 25, 2012 6:10pm
  • #1 / Jul 25, 2012 6:10pm
    Jaedis
    I have installed EE v2.5.2
    I have the site Template Group.  It contains the index.  When Im in the Template Manager and I click on the view for the default index template I get the redirect and then a Page Not Found Error.  The path looks like this:
    http://www.unifyingmeditation.org/index.php/site
    When I change the path to this:
    The Page shows up fine.
    I also have a Template Group called TestSite, also with the default index and get the same error when I try to view the index via the Template Manager.  I click view and get the redirect to this link:
    http://www.unifyingmeditation.org/index.php/TestSite
    Any help would be greatly appreciated.
  • #2 / Jul 26, 2012 5:05pm
    Jaedis
    I am re-installing Expression Engine 2.5.2 to see if it was a kink in the install so please disregard the links above.  I will repost if it happens again.
    Crossing My Fingers.
  • #3 / Jul 26, 2012 5:56pm
    Jaedis
    Update:
    I have re-installed EE with a fresh database.  Still the same issue as stated above but I have tested with Firefox and get this error instead of the 404 page not found.
    No input file specified.
    I did a search and it seems individuals on Godaddy have expienrenced this.  This site is hosted with GoDaddy.
    http://www.noinputfilespecified.com/
    Please if anyone else is having this issue, I really need some brains on this one.
  • #4 / Jul 26, 2012 6:22pm
    Jaedis
    Found the answer for anyone else having this issue:
    http://ellislab.com/forums/viewthread/130554/
    Admin/System Administration/Output and Debugging/  Set Force URL query strings to Yes.
  • #5 / Jul 26, 2012 6:37pm
    Ack- welcome to the forums, Jaedis.  Sorry you ran into an issue and then had to hunt the solution down yourself.  Indeed, forcing query strings is the solution if you run into the 404 issue after install.  Note- if you use htaccess to remove index.php, it should still work for you.  Just tweak it in the htaccess files.
    And if you run into any more issues, just let us know!
  • #6 / Oct 13, 2012 6:45pm
    jaedis, just wanted to let you know that I ran into this issue and your posts have helped me fix the same error. I appreciate you posting your solutions on the forums. Thanks again!
  • #7 / Oct 15, 2012 9:11pm
    😉  Indeed- glad Jaedis helped get you squared way!
