Upgrade from 1.7.0 to 2.5.2
July 15, 2012 1:35pm
  • #1 / Jul 15, 2012 1:35pm
    bakerave
    Upgrade from 1.7.0 to 2.5.2; no errors while going through the update; able to access the control panel; however when attempting to access the main site the following error pops up:
    Error
    The following tag has a syntax error:
    {exp:selected}
    Please correct the syntax in your template.
    If turn on Display Template Debugging it shows nothing additional; performing the update on a staging system with DNS for the live site pointing to the local machine.
    On 1.7 turning on the template debugging would at least provide some data; 2.5 doesn’t provide any data.
    No errors in the php logs or apache logs.
  • #2 / Jul 15, 2012 1:39pm
    Boyink!
    Looks like an add-on that needs to be updated for EE2.
  • #3 / Jul 15, 2012 4:24pm
    bakerave
    Thanks but there are no add-ins being used in the templates.
  • #4 / Jul 15, 2012 4:42pm
    Boyink!
    EE thinks otherwise..😊
    exp:selected isnt native code.
    Looks like http://www.solspace.com/docs/detail/selected_selected/
  • #5 / Jul 15, 2012 5:08pm
    bakerave
    Thanks your right it wasn’t registered in the modules and it was Solspace that setup the original site.
  • #6 / Jul 15, 2012 5:13pm
    Boyink!
    It wasn’t showing in Modules because it’s a Plugin - both are add-on types.  Plug-ins are much smaller, don’t require database tables etc.
  • #7 / Jul 17, 2012 11:59am
    Shane Eckert
    Hey bakerave,
    Thank you for posting your question here on the ExpressionEngine forums.
    I see that Mike has been able to help you out!
    How are things going? Is there anything else I can help with?
