Client requiring PCI compliance
July 12, 2012 12:35pm
Subscribe [4]
  • #1 / Jul 12, 2012 12:35pm
    Chris Arnold
    A client of ours needs total PCI compliance (medical-related website). We initially passed the first scan last month with help from our host and all seemed fine. But this week a new scan failed at the login screen for EE. The details:
    Path: /admin/admin.php?S=0=cp=login
    Poor authentication practices may leave the web application vulnerable to authentication attacks.
    Solution:
    To use HTML form-based authentication more securely in web applications, do the following:
    - Remove the value attribute from the INPUT tag corresponding to the password field.
    - Submit all forms to an SSL-enabled (https) service using the form’s action attribute.
    - Place all protected web directories on an SSL-enabled (https) service.
    - Use the autocomplete=“off” attribute in the INPUT tag corresponding to the password field.
    A few things. We access the CP through /adm and not /admin. I also did a search on HTTPS for the CP and didn’t find much definitive information in return (just a handful of broken / hacky options). Wasn’t sure, too, if I could manually adjust the login form HTML itself to mitigate the scan error.
    What do you think?
  • #2 / Jul 12, 2012 2:44pm
    Enviromed
  • #3 / Jul 12, 2012 3:25pm
    Chris Arnold
    Interesting. We’re already using the free DM Force SSL plugin for a few pages on the site. Any idea if this works in the CP? I’ll contact the dev, too.
  • #4 / Jul 16, 2012 11:04am
    Shane Eckert
    Hey Chris,
    That Add-On looks promising. Would you mind reporting back here as to what you find?
    Thank you,
  • #5 / Jul 16, 2012 11:07am
    Chris Arnold
    I am in communication with the dev at this time. He is working on a revision to get to me in a day or two. I will report back. Thanks.
  • #6 / Jul 17, 2012 1:28pm
    Shane Eckert
    Hey Chris,
    Awesome. I will be on the lookout for your update!
  • #7 / Jul 20, 2012 12:52pm
    Chris Arnold
    It looks like the Force SSL add-on may work. I have been in contact with the dev who managed to setup a truly HTTPS control panel (after a few days of modification). Still a few small kinks, but it’s doing what it’s supposed to at the first few glances here.
  • #8 / Jul 20, 2012 5:34pm
    Shane Eckert
    Hey Chris,
    Awesome. Thanks for the update.
    I will keep this open a bit if you would like.
  • #9 / Jul 20, 2012 5:35pm
    Chris Arnold
    I think we’ll be all set. Feel free to close it down. I will repost if needed. Thanks!
  • #10 / Jul 20, 2012 5:38pm
    Shane Eckert
    Hey Chris,
    Sounds good!
