So this issue has been on the back burner for a while, but I’m back trying to get the problem fixed. After reviewing the messages above, I still haven’t found a solution. So here’s what I’m thinking:
1. Visitors get to the login page by clicking the “sign in” link which has the path: path=‘member/login/. I have not directly embedded the login form in any of the templates I’ve created by using
{exp:member:login_form return=“site/landing_page”}
2. Visitors are directed to the “Login Form” template in the member profile templates. I do not see anywhere in this template where the landing page is set unless it is somehow connected to “{form_declaration}” at the top of the page(somehow I changed the landing page several months ago because it is linking to an entry I created and not the home page).
3. If the landing page is not set in the “Login Form” template it must be set in another member profile template that links to the “Login Form”, or maybe there is a variable somewhere that sets the landing page. If all this is determined using member profile templates, someone must know how these member profile template paths are set up and how the “Login Form” knows where to direct to.
4. You’ve suggested searching the templates I’ve created for “login_form”. Is there any easy way that I can do a search for that term in all my templates at once, or do I have to open them one by one?
Sorry if this is just rehashing what I’ve already posted. Any new thoughts on how to solve this?
Phillip
