Htaccess problems
July 04, 2012 3:02pm
  • #1 / Jul 04, 2012 3:02pm
    amimpact
    When deploy an Expression engine website I had some problems with the htaccess. On http://expressionengine.com/docs_assets/general/remove_index.php.html there is an example that says the following:
      # If 404s, “No Input File” or every URL returns the same thing
      # make it /index.php?/$1 above (add the question mark)
    What difference does the question mark make in this case?
    I tested this on 2 different hosting platforms. One of the hosting platforms showed an error like “no input file”.
    After adding the questionmark the site only worked when index.php was in the url. For every other url that was called, the homepage was shown.
    How could this happen?
  • #2 / Jul 04, 2012 3:58pm
    MadWebDesigns
    Hi amimpact,
    Please post the entire contents of your htaccess file so we can have a look.
    Thank you,
    Mike
  • #3 / Jul 05, 2012 1:53am
    amimpact
    Here is de content of the .htaccess
    <IfModule mod_rewrite.c>
      RewriteEngine On
    # always redirect to main domain with 301
      RewriteCond %{HTTP_HOST} !^www.domainname.com$
      RewriteRule ^(.*)$ http://www.domainname.com/$1 [R=301,QSA,L]
      # Removes index.php
      RewriteRule ^(.*)$ index.php/$1 [L]
    </IfModule>
  • #4 / Jul 05, 2012 10:21am
    MadWebDesigns
    I think this should fix it for you:
    RewriteCond %{HTTP_HOST} !^www\.domainname\.com$
    RewriteRule ^(.*)$ <a href="http://www.domainname.com/$1">http://www.domainname.com/$1</a> [R=301,QSA,L]
    # Removes index.php
    RewriteCond $1 !\.(css|js|swf|gif|jpe?g|png|ico)$ [NC]
    RewriteRule ^(.*)$ /index.php?$1 [L]
    Mike
  • #5 / Jul 05, 2012 11:27am
    Shane Eckert
    Hey amimpact,
    I am glad that Mike has been able to help you out here.
    If his example does not work for you, you may want to head over to Community Help Forum. The only version of the .htaccess file that we support is the following.
            RewriteEngine On
            # Removes index.php
            # If 404s, "No Input File" or every URL returns the same thing
    </IfModule>
    Please let me know if there is anything else I can do.
  • #6 / Jul 19, 2012 5:08am
    amimpact
    Thanks for the examples.
    I want to know what de questionmark does in this exact situation.
    Why won’t it work if the questionmark is not used?
    How can it be that only the homepage will be shown?
  • #7 / Jul 19, 2012 4:10pm
    Shane Eckert
    Hey amimpact,
    These are good questions!
    This here should explain why the questions mark is needed. Each server is different and some require query strings.
    The homepage shows because it’s the homepage. There is not other segments in the URL which would require or not require query strings. Does that make sense?
