Upgrade 1.7 to 2 x css not rendering
July 02, 2012 6:50pm
  • #1 / Jul 02, 2012 6:50pm
    pserko
    Did upgrade for a very large site with multiple “channels”.  CSS not rendering.  Content appears but styles not applying.  Can’t even preview stylesheet from within the template manager “view option”, nothing appears.
    Debugging messages:
    TEMPLATE DEBUGGING
    (0.000020 / 4.62MB) - Begin Template Processing -
    (0.001242 / 4.66MB) URI: css=district2/channel_css
    (0.001283 / 4.66MB) Path.php Template: /
    (0.001319 / 4.66MB) Retrieving Template
    (0.001350 / 4.66MB) Parsing Template URI
    (0.002257 / 4.66MB) Template group and template not found, showing 404 page
    (0.002303 / 4.67MB) Retrieving Template from Database: /
    (0.004088 / 4.67MB) Template Not Found
    (0.004146 / 4.66MB) Template Type: 404
    (0.004193 / 4.66MB) Parsing Site Variables
    (0.004290 / 4.67MB) Snippets (Keys): freelancer_version|site_id|site_label|site_short_name|last_segment
    (0.004325 / 4.67MB) Snippets (Values): FALSE|1|VISD|visd|channel_css
    (0.004644 / 4.67MB) Parse Date Format String Constants
    (0.004688 / 4.67MB) Parse Current Time Variables
    (0.004731 / 4.67MB) Parsing Segment, Embed, and Global Vars Conditionals
    (0.007914 / 4.73MB) - Beginning Tag Processing -
    (0.007957 / 4.73MB) - End Tag Processing -
    (0.008041 / 4.73MB) - End Template Processing -
    (0.008066 / 4.73MB) Parse Global Variables
    (0.009663 / 4.73MB) Template Parsing Finished
    Memory Usage: 4,967,336 bytes
  • #2 / Jul 03, 2012 4:08pm
    Shane Eckert
    Hey pserko,
    Can you double check your paths and that you have the right template group/template listed in the template? This “feels” like a path is not right somewhere, either for the channel or in general configuration.
    What version of ExpressionEngine are you currently using?
    The template type is CSS, correct?
    Can you show me how you are calling the CSS?
    Please let me know!
  • #3 / Jul 04, 2012 12:46am
    pserko
    <link rel=“stylesheet” type=“text/css” media=“all” href=”{stylesheet='district2/site_css'}” />
    or
    <link rel=“stylesheet” type=“text/css” media=“all” href=”{stylesheet='{template_group}/site_css’}” />
    All these worked in 1.7.  Not a single one works in 2x.  I resorted to an external stylesheet as a work around.
    Just to so you know…  this site has been running on EE since the first version of EE and as gone through all the updates.  There are 60 channels and 1298 categories.  I had a problem once where I couldn’t add categories because a DB bit was not set correctly in the incremental update process of over the years.  Took a big effort from EE tech support to track that down..  I mention this just in case this is due to something odd like that.
    Thanks for your help.
  • #4 / Jul 05, 2012 1:16pm
    Shane Eckert
    Hey pserko,
    Is there anything else I can help with?
  • #5 / Jul 05, 2012 2:21pm
    pserko
    Well, I would really like to get to the bottom of this.
  • #6 / Jul 05, 2012 4:28pm
    Shane Eckert
    Hey pserko,
    What version of ExpressionEngine are you currently running.
  • #7 / Jul 05, 2012 6:17pm
    pserko
    2.5.1
  • #8 / Jul 06, 2012 3:35pm
    Shane Eckert
    Hey pserko,
    I would like to get in and take a look.
    Please be on the lookout for an email from EllisLab.
