Problem with supported index.php removal method
June 29, 2012 5:25pm
  • #1 / Jun 29, 2012 5:25pm
    Versa Studio
    I’m using this method:
    <IfModule mod_rewrite.c>
            RewriteEngine On
            # Removes index.php
            # If 404s, "No Input File" or every URL returns the same thing
            # make it /index.php?/$1 above (add the question mark)
    </IfModule>
    However, I am getting some undesired behavior. For example, the URL:
    http://versastudio.com/l/wisconsin-a
    gets rewritten to
    http://versastudio.com/index.php/l/wisconsin-b
    Ideas?
  • #2 / Jun 29, 2012 8:56pm
    boldyellow
    Just throwing a couple thoughts out here…
    Remove the “index.php” from the “Name of your site’s index page” in Admin > General Configuration.
    Try the add question mark in the .htaccess comment (I once had to do that for one web host).
  • #3 / Jul 03, 2012 11:09am
    Dan Decker
    Hi Versa Studio,
    As bold yellow points out, have you made sure to remove it from Admin->General Configuration?
    Another option is to double check with your host that .htaccess re-writes are enabled.
    I look forward to your reply!
  • #4 / Jul 03, 2012 2:12pm
    Versa Studio
    “Name of your site’s index page” is blank.
    Rewrites are enabled, the site is on Engine Hosting.
  • #5 / Jul 03, 2012 2:35pm
    That .htaccess rule you’re using doesn’t have anything to do with a URL redirect; all it does is process a request with index.php if the request isn’t for a file or a directory; see my comments below:
    RewriteCond $1 !\.(gif|jpe?g|png)$ [NC] #If not ending in gif, jpg, jpeg, or png
    RewriteCond %{REQUEST_FILENAME} !-f # If not a file
    RewriteCond %{REQUEST_FILENAME} !-d # If not a directory
    RewriteRule ^(.*)$ /index.php/$1 [L] # Process request with index.php
    You want something like this (which also kills the www subdomain, if that’s something you’re interested in):
    # Enable Rewrite Engine
    # Use RewriteBase to define path to base of EE install, e.g. /development/project-name/, if not in root of domain
    RewriteEngine on
    RewriteBase /
    # Kill www subdomain
    # Example: <a href="http://www.example.com/foo/">http://www.example.com/foo/</a> -> <a href="http://example.com/foo/">http://example.com/foo/</a>
    # Doesn't apply to https URLs
    RewriteCond %{HTTPS} !=on
    RewriteCond %{THE_REQUEST} ^GET [NC]
    RewriteCond %{HTTP_HOST} ^www\.(.+)$ [NC]
    RewriteRule ^(.*)$ http://%1/$1 [R=301,L]
    # In any request contains "index.php"  ...
    # ... and is an Apache GET request ....
    # Then ...
    # ... redirect to the requested location without "index.php"
    RewriteCond %{THE_REQUEST} ^GET.*index\.php [NC]
    RewriteRule (.*?)index\.php/*(.*) $1$2 [R=301,L]
    # This rule is needed if query string is given to homepage w/o template name in URI, e.g. example.com instead of example.com/default_template_group_name
    # Note: you must may have to change the name of the default template group in this rule to match your setup
    # If any request request that is not at least 1 char long ...
    # ... and contains any sort of query string 1 or more chars in length ...
    # ... and doesn't contain a query string of "css=" or "URL=" or "ACT=" ...
    # Then ...
    # ... process it with /index.php?/[defult template group]/[request]
    RewriteCond %{QUERY_STRING} ^(.+)$
    RewriteCond %{QUERY_STRING} !(css|URL|ACT)=
    RewriteRule !^(.+)$ index.php?/site/$1 [L]
    # This rule is needed to handle query strings in EE
    # If entire any request ...
    # ... doesn't contain an image, css, or js extension, ...
    # ... and isn't a file name ...
    # ... and isn't a directory name ...
    # Then ...
    # ... process it with /index.php?/[request]
    RewriteCond $1 !\.(css|js|gif|jpe?g|png) [NC]
    RewriteRule ^(.*)$ index.php?/$1 [L]
    # If entire request ...
    # Then ...
    # ... process it with /index.php/
    RewriteRule ^(.*)$ index.php/$1 [L]
  • #6 / Jul 03, 2012 2:45pm
    Versa Studio
    Thanks Nick. I was using NSM HtAccess Generator, but its code interferes with CartThrob. So I went back to the simple, supported method from Ellis Lab.
  • #7 / Jul 04, 2012 5:06pm
    Dan Decker
    Hi Versa,
    Checking the links in your first post, everything seems to be on the mend here?
    Is there something I’m missing or anything else I can assist you with?
  • #8 / Jul 05, 2012 2:59pm
    Versa Studio
    Try the first link - it redirects to a different URL, which it should not do.
  • #9 / Jul 06, 2012 10:58am
    Shane Eckert
    Hey Versa Studio,
    I tried the first link.  http://versastudio.com/l/wisconsin-a points to http://versastudio.com/l/wisconsin-a. There is no index.php for me.
    Is it not working for you?
  • #10 / Jul 10, 2012 1:14am
    Versa Studio
    Strange - mine is giving me different url titles. In two different browsers.
  • #11 / Jul 11, 2012 12:31pm
    Dan Decker
    Hi Versa Studio,
    Let’s get in there for a first hand look. Be on the lookout for an email from us!
  • #12 / Jul 12, 2012 11:34am
    Shane Eckert
    Hey Versa Studio,
    Can you use the same method here as I gave you for your other case?
  • #13 / Jul 12, 2012 3:04pm
    Versa Studio
    Info sent.
  • #14 / Jul 12, 2012 3:07pm
    Shane Eckert
    Hey Versa Studio,
    Awesome!
    Dan will be looking into this.
