Translations made in language files AND translation utility are ignored
June 28, 2012 4:41pm
  • #1 / Jun 28, 2012 4:41pm
    atle
    I’ve experienced this a few times before, but this time I really need to translate a few error-messages for form submissions.
    I’ve duplicated the “english” folder in the language folder and renamed it “norsk” (Norwegian). I then selected “norsk” in Admin > General Configuration. Any changes I make either through the translation utility in the CP, OR in the file itself doesn’t show up anywhere…
    As soon as I switch back to “english”, and make changes in the files, it works, although when I use the translation utility, nothing changes.
    Are there any other settings I need to adjust to make this work? Anybody else had this issue with syncing?
    As for now, I’m translating the “english” files in a text editor, but I’d really like to have a dedicated folder for all my translations…
    PS: Running EE 2.5.2 - Build Date: 20120606.
  • #2 / Jun 29, 2012 2:26pm
    Dan Decker
    Hi atle,
    I’m sorry for the frustration with the translation utility.
    I can explain how the utility works, it’s not very intuitive!
    First, make sure that /system/expressionengine/translations is writable and set with 777 permissions.
    Then, you make your translations in the translation utility and they are saved to the translations folder.
    Create a folder named for the language of the translation and move the file in /system/expressionengine/translations to this new language folder.
    Then, place that folder in /system/expressionengine/language/
    You should now be able to set your translation in the Control Panel by selecting it in Admin->General Configuration
    Let me know if you have any questions!
  • #3 / Jul 23, 2012 4:19pm
    atle
    Hi Dan, thanks for the reply, that sure cleared things up for me. I should have checked the permissions, that one was obvious…
    Atle
  • #4 / Jul 24, 2012 12:27pm
    Dan Decker
    Hi Atle,
    Cheers!
