Learning to slice & code CSS
June 28, 2012 2:02pm
  • #1 / Jun 28, 2012 2:02pm
    ruckus
    Hi all,
    My apologies for asking such a noob question, but I want to quickly get up to speed in learning how to slice and code CSS. Are there any easy to use guides on this? I don’t mind paying. I have knowledge of HTML from about 10 years ago.
    Dan
  • #2 / Jun 29, 2012 10:57pm
    Roi Agneta
    Dan, afraid that there is no quick way to master CSS - the path to expertise is the same as almost every other endeavor: practice.  I would suggest a couple of good blog sites.  The awesome http://css-tricks.com/ is a must.  Google CSS and you will find plenty of others.  The other thing you should do is use Firebug (or equivalent) to investigate the CSS of your favorite websites.
    Good luck!
  • #3 / Jul 03, 2012 2:44pm
    pixelbaker
    You also need to learn a bit Photoshop if going to slice.
    If you are working for yourself instead of customers, I suggest you learn HTML5+CSS2 directly without wasting too much time on slicing.
    The trend today is to code directly with less slicing.
