Double Nesting Embeds/Snippets?
June 22, 2012 6:49pm
  • #1 / Jun 22, 2012 6:49pm
    bmpire
    Hello,
    The EE system allows the ability nest a snippet with an embed statement.  However, how can you add another snippet or embed level to this?
    I would like to have a snippet nested within an embed which is also nested within an embed or snippet.
    How can I accomplish this?
    Brandon
  • #2 / Jun 22, 2012 7:23pm
    R.K.Foster
    Exp Eng parses the content of your templates in a particular order. (There is a pdf somewhere that lists the full parsing order) Snippets are near the beginning and embeds are parsed after that. You should be able to use the snippets wherever but the parsing order may not get you the results you expect. Is there something you’ve tried that hasn’t worked? Maybe you could post an example?
    - Bob.
  • #3 / Jun 25, 2012 4:23pm
    Shane Eckert
    Hey BMPIRE,
    Bob is right on. He mentioned the Parse Order document by Low. This is a good place to start.
    Can you post an example as Bob mentioned?
