I’m not sure if this is even possible but I’m simply trying to pass a channel field into a php variable. My client needs to be able to add new stock symbols via a channel field. Any help/suggestions would be appreciated. This current code does “work” but it’s throwing php errors. I don’t know if creating a snippet or embedding would work better?
{exp:channel:entries channel="stock_symbols" limit="1"}
<?php
echo "<ul class=\"ticker\">";
$up = "{image_path}/up.png";
$down = "{image_path}/down.png";
// Original script by Walter Heitman Jr, first published on <a href="http://techblog.shanock.com">http://techblog.shanock.com</a>
// List your stocks here, separated by commas, no spaces, in the order you want them displayed:
$stocks = "{symbols}";
// Function to copy a stock quote CSV from Yahoo to the local cache. CSV contains symbol, price, and change
function upsfile($stock) { copy("http://finance.yahoo.com/d/quotes.csv?s=$stock&f=sl1d1t1c1ohgv&e=.csv","stockcache/".$stock.".csv"); }
foreach ( explode(",", $stocks) as $stock ) {
// Where the stock quote info file should be…
$local_file = "stockcache/".$stock.".csv";
// ...if it exists. If not, download it.
if (!file_exists($local_file)) { upsfile($stock); }
// Else,If it's out-of-date by 15 mins (900 seconds) or more, update it.
elseif (filemtime($local_file) <= (time() - 900)) { upsfile($stock); }
// Open the file, load our values into an array…
$local_file = fopen 〈"stockcache/".$stock.".csv","r");
$stock_info = fgetcsv ($local_file, 1000, ",");
// ...format, and output them. I made the symbols into links to Yahoo's stock pages.
echo "<li class=\"tick-text\"><span>".$stock_info[0]." </span>".sprintf("%.2f",$stock_info[1])." <span>=0) { echo "color: #62a800;\">$up "; }
elseif ($stock_info[2]<0〉 { echo "color: #ff0000;\">$down "; }
echo sprintf("%.2f",abs($stock_info[2]))."</span></span></li>\n";
// Done!
fclose($local_file);
echo "</ul>";
